Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 550 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
I'm having trouble identifying the items from my 2.0 Victor Reinz gasket kit.
The little copper ones are identical to the washers I used for the temp sensor bottom plate. The black gasket is a little bit smaller and thicker than the seal used for the pushrod tube small end. Is it for the distributer? The silver washer looks like it's for the bottom temp sensor, but I would be surprised if the kit included that gasket. I can't find where the larger 2 copper washers fit. ![]() |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
If you take a close look at the black o ring, you'll see its flat on the inside. It's definitely for the diz. Really its a "d" ring.
The two larger copper washers are too small for the pressure relief valve. They look more the size of the oil drain and sump cover |
Lo-Fi Version | Time is now: 13th July 2025 - 07:46 PM |
