| moggy |
Jun 22 2013, 02:38 AM
Member ![]() ![]() Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
It's time I moved out of the dark ages and got myself a dry sump system on the rallycar. What's everyone using? Any pictures of installations? especially with the stock cooling. My concern is that I'll have to do some major surgery on the fan shroud (4 cylinder engine) as any dry sump pump will sit so far proud that I'll have to cut a hole in the fan shroud. Really interested to see what everyone has done. (IMG:style_emoticons/default/beerchug.gif)
| moggy |
Dec 12 2013, 09:02 AM
Aaron - I looked at that option but decided against it for a number of reasons:
1 - The engine/gearbox needs to be really held in as strong as possible in the rallycar, all that heavy vibration and big hits really tests all mounting points out to the limit. For this reason I didn't feel comfortable only holding it all in on just the bottom 2 bolt holes 2 - With the vibrations experienced in rallying I wanted to have some kind of rubber seated engine mounts to absorb at least some of the pounding. 3 - I couldn't see how a straight bar was going to allow me to avoid the gear linkage. For these reasons I went with the standard engine bar and modded mounts. Last night I managed to find some good solid rubber machinery mounts that are ideal as engine mounts, they're even the same diameter - what are the chances of that eh? (IMG:style_emoticons/default/biggrin.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/i31.photobucket.com-3285-1386860525.1.jpg) Using the mounts I cut of the back plates last night, I offered them up and found a problem on the right hand side - it now knocks into the old oil filler blockoff as you can see (the engine I'm using to mock everything up does not have the blockoff plate on, as you can see, but believe me it knocks into it). This means I'm going to need to shave off about 10mm from the right side of the mount to get it to fit. (IMG:http://www.914world.com/bbs2/uploads_offsite/i31.photobucket.com-3285-1386860525.2.jpg) On the left side, all is well, although I'll still shave off 10mm to match the other side. Whilst at this point I checked measurement away from the backplate again to ensure it's all still at the smidge over 1 inch. Still looking good. (IMG:http://www.914world.com/bbs2/uploads_offsite/i31.photobucket.com-3285-1386860526.3.jpg) You'll notice in the above to shots that there's gap between the mount and back plate, this was from the amount of metal the cutting disk bit out when I cut the mounts off the back plates earlier in the process. To fill in this gap and to also add strength to the mounts in their lower postions it's necessary to weld in a small additional plate, as you can see below: (IMG:http://www.914world.com/bbs2/uploads_offsite/i31.photobucket.com-3285-1386860526.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i31.photobucket.com-3285-1386860526.5.jpg) And here's where we're up to at the moment. All tacked up roughly. Offered it up to the engine bar. All fits perfectly. Next steps - weld up what I have, clean it up, maybe add another strengthening gusset. (IMG:http://www.914world.com/bbs2/uploads_offsite/i31.photobucket.com-3285-1386860972.1.jpg) That's all for now folks (IMG:style_emoticons/default/santa_smiley.gif) |
moggy Dry sump systems Jun 22 2013, 02:38 AM
tomeric914 I was going to go dry sump with the four, but swit... Jun 22 2013, 12:15 PM
McMark I bought a TypeI Auto-Stick oil pump with fits in ... Jun 22 2013, 05:44 PM
Matt Romanowski I would be concerned with the scavenge on that pum... Jun 22 2013, 07:22 PM
moggy Thanks for the feedback so far guys. I've done... Jun 23 2013, 03:33 PM
bam914 Get a pump from Thorsten Pieper. It is a 2 stage ... Jun 23 2013, 04:37 PM
moggy
Get a pump from Thorsten Pieper. It is a 2 stage... Jun 23 2013, 11:59 PM
Racer Chris I use the CB 2 rotor pumps.
The front inlet and ou... Jun 23 2013, 04:39 PM
Randal
The front inlet and o... Jun 23 2013, 08:25 PM
dlestep
Do you get additional HP by running a dry sump oi... Jun 23 2013, 08:46 PM
bam914 It was over $400.00. He is in Germany. You ... Jun 24 2013, 09:43 AM
moggy
It was over $400.00. He is in Germany. You... Jun 25 2013, 01:06 AM
moggy I'm going for the Thorsten Pieper pump (Thanks... Jun 28 2013, 12:00 PM
moggy
It was over $400.00. He is in Germany. You... Dec 8 2013, 02:59 PM
bam914
It was over $400.00. He is in Germany. Yo... Dec 9 2013, 09:44 PM
moggy
Never got to that point. Sorry
No worries :bee... Dec 11 2013, 05:39 AM
r_towle If you go to the 911 cooling shroud, everything fi... Jun 24 2013, 03:40 PM
moggy Quick question.....
What do I do with the current... Jun 28 2013, 12:42 PM
moggy
Quick question.....
What do I do with the curren... Jul 8 2013, 02:42 PM
yeahmag My build shows most everything you need to know:
... Jun 28 2013, 05:27 PM
stugray Anyone have complete diagrams?
I have read most o... Jul 5 2013, 08:24 PM
yeahmag RE: Dry sump systems Jul 6 2013, 09:01 AM
stugray That helps but it doesnt show the other half.
That... Jul 6 2013, 12:02 PM
john rogers Some things to remember about dry sump systems.
- ... Jul 7 2013, 07:28 PM
moggy
-... Jul 8 2013, 02:39 PM
Racer Chris You will need to loop them together, not block the... Jul 8 2013, 03:54 PM
moggy
You will need to loop them together, not block th... Jul 9 2013, 03:17 PM
moggy
You will need to loop them together, not block th... Jul 9 2013, 04:09 PM
Racer Chris That looks like just the ticket. Jul 9 2013, 06:28 PM
Borderline It's been a while since I did my engine build,... Dec 11 2013, 12:30 PM
yeahmag I used a single peace of strong angle iron and onl... Dec 11 2013, 12:48 PM
pcar916 ... as well you'll have to calculate the prope... Dec 12 2013, 09:31 AM![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2025 - 08:14 PM |
