gryphon68 |
Member ![]() ![]() Group: Members Posts: 61 Joined: 2-October 13 From: SE Michigan Member No.: 16,462 Region Association: Upper MidWest ![]() |
What is the best match for rear brake calipers if I am planning a 5-lug conversion with 1970 911T Struts and hubs? Leaning towards the 3" Brembo Aluminum calipers in front, the lightweight is a big plus in my opinion.
Hoping to use the 911 parking brake in the back, so no need for complicated rear calipers with internal parking brake. Besides a 3" M-Caliper (38mm?) what are the other options for the rear calipers? Something lightweight would be a bonus . . . If I where to run a dual master cylinder pedal with balance bar would it be possible to just use another set of the 48mm Brembo Aluminum calipers on the rear? |
tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,268 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
Stumbled across these images as well:
(IMG:http://www.914world.com/bbs2/uploads/post-2-1107358864.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-721-1194291617.jpg) And this one with the wider spacer mod mentioned above. In this case it was for Corvette brakes: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.vettemod.com-9101-1386875994.1.jpg) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,414 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Stumbled across these images as well: (IMG:http://www.914world.com/bbs2/uploads/post-2-1107358864.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-721-1194291617.jpg) And this one with the wider spacer mod mentioned above. In this case it was for Corvette brakes: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.vettemod.com-9101-1386875994.1.jpg) That first picture is mine. I have one piece of advise for you. DON'T DO IT! I tried it, and Wes Hildreth tried it on a car owned by Mike Floyd here in the DFW area. We learned that if you set the park break with the rotor hot, you need a big assed hammer to get them to release. There was no spring we could find that was strong enough to pull the pads loose. Wilwood used to sell that setup for their Ford 9 inch and Chevy 12 bolt disk brake kits. They have all been replaced with an internal drum brake like the 911 park brake. I called them and asked, and they had the same problem we did. |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Stumbled across these images as well: (IMG:http://www.914world.com/bbs2/uploads/post-2-1107358864.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-721-1194291617.jpg) And this one with the wider spacer mod mentioned above. In this case it was for Corvette brakes: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.vettemod.com-9101-1386875994.1.jpg) That first picture is mine. I have one piece of advise for you. DON'T DO IT! I tried it, and Wes Hildreth tried it on a car owned by Mike Floyd here in the DFW area. We learned that if you set the park break with the rotor hot, you need a big assed hammer to get them to release. There was no spring we could find that was strong enough to pull the pads loose. Wilwood used to sell that setup for their Ford 9 inch and Chevy 12 bolt disk brake kits. They have all been replaced with an internal drum brake like the 911 park brake. I called them and asked, and they had the same problem we did. The second picture is of mine. I read about the sticking pad problem, but have yet to experience it....Knock on wood! I too called Wilwood, and the guy I spoke with heard of no such problem. Andys |
Lo-Fi Version | Time is now: 1st July 2025 - 02:59 PM |
