| 2mAn |
Nov 26 2013, 12:23 AM
trying to see how long I can go without a 914 ![]() ![]() Group: Members Posts: 499 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
My searching hasnt gotten me very far. Im sure most of you hate the idea, and thats fine. I am in the research phase and havent done anything yet, but I am close to purchasing the 914 and want to have a solid gameplan prior to purchasing the vehicle.
SO whos done it, I know of a 20v turbo here on the board, but havent seen any others. Thanks -Simon |
| 2mAn |
Dec 5 2013, 06:13 PM
bumping this back up since it looks like the Rabbit will finally be sold and the garage spot will be open for my project...
| 2mAn |
Dec 16 2013, 01:01 PM
BUMP
Im with you on the bellhousing side, just curious what flywheel/clutch/PP setup Id have to use. Im assuming it depends on the transmission I use, yes? You lost me on the flanges, I know you are referring to the size that attaches to the CVs, but what size flange do the 914s have? 108mm? or 90mm?? something else?? |
| Mike Bellis |
Dec 16 2013, 05:55 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
BUMP Im with you on the bellhousing side, just curious what flywheel/clutch/PP setup Id have to use. Im assuming it depends on the transmission I use, yes? You lost me on the flanges, I know you are referring to the size that attaches to the CVs, but what size flange do the 914s have? 108mm? or 90mm?? something else?? I believe the stock size is 94mm. Early 911 outer stub flanges will fit in either a 100mm or 108mm flange size. it's a bolt on swap if you get the right ones. if you get the wrong ones, you need a 5mm spacer ring. I just made some 108mm flanges for my Boxster/Passat 5 speed tranny. I chocked up the flanges in my lathe, machined off the 100mm bolt pattern and carefully welded a 108mm adapter onto the flange. I then spun it in the lathe again to check it for true. I welded it like a structural double pass weld. Good heat. Good penetration. Came out pretty god and better than expected. picture will show up in my build thread soon. BTW, I have a set of 100mm outer flanges for sale if anyone needs them. |
2mAn Watercooled VW / Audi motor swaps? Nov 26 2013, 12:23 AM
SirAndy it IS a VW afterall, right?
Actually no, the 914 w... Nov 26 2013, 02:18 AM
2mAn
Actually no, the 914 ... Nov 26 2013, 12:18 PM
jimkelly most conversions here are either
Porsche 6 and 91... Nov 26 2013, 06:05 AM
Mark Henry IIRC the engine sits too high or is too long. Nov 26 2013, 06:46 AM
dlestep There have been a few, here and there.
Only becaus... Nov 26 2013, 08:45 AM
gothspeed
Only becau... Nov 29 2013, 02:14 PM
Mike Bellis I think it's a great idea to install a 20v tur... Nov 26 2013, 08:58 AM
dlestep
I think it's a great idea to install a 20v tu... Nov 26 2013, 09:03 AM
jimkelly http://www.914world.com/bbs2/index.php?sho...c=850... Nov 26 2013, 09:09 AM
Cap'n Krusty A late 90s TDi would make a nice swap ............... Nov 26 2013, 09:51 AM
Dave_Darling
A late 90s TDi would make a nice swap .............. Nov 26 2013, 12:29 PM
jeffdon
A late 90s TDi would make a nice swap .............. Dec 17 2013, 04:50 PM
championgt1 Not sure if he ever finished it.
http://www.914wo... Nov 26 2013, 12:29 PM
paroxysm
http://www.914w... Dec 31 2013, 05:05 PM
2mAn So Ive been chatting via PM with rohar who has don... Nov 29 2013, 01:04 PM
rohar
So Ive been chatting via PM with rohar who has do... Nov 29 2013, 01:50 PM
Mike Bellis Some Audi transmissions have a 100mm flange the ma... Nov 29 2013, 02:21 PM
rohar Given the engine at play, you could go with the Au... Nov 29 2013, 02:58 PM
2mAn I think Im going to have to go with the 4000 trans... Nov 29 2013, 03:44 PM
rohar
I think Im going to have to go with the 4000 tran... Nov 29 2013, 03:50 PM
Mike Bellis I always thought it was neat the way all the Audi ... Nov 29 2013, 04:26 PM
rohar THANKS MIKE! That was kinda what I was trying... Nov 29 2013, 05:28 PM
Mike Bellis
THANKS MIKE! That was kinda what I was tryin... Nov 29 2013, 05:31 PM
rohar
THANKS MIKE! That was kinda what I was tryi... Nov 29 2013, 05:38 PM
2mAn I'll be in San Jose next week. I might even ow... Dec 17 2013, 12:43 AM
larryM depends on your objective - PCA frowns on hybrids ... Dec 17 2013, 03:03 PM
damesandhotrods
depends on your objective - PCA frowns on hybrids... Dec 17 2013, 05:08 PM
2mAn As far as a TDI goes it depends in which year. Tec... Dec 17 2013, 06:38 PM
Rotary'14
As far as a TDI goes it depends in which year. Te... Dec 17 2013, 07:02 PM
Mike Bellis
As far as a TDI goes it depends in which year. Te... Dec 17 2013, 07:53 PM
2mAn
[size=3]Yes it is legal to swap an engine from an... Dec 20 2013, 11:42 AM
914_teener One caviat Mike:
74 and 75 had smog equipment so... Dec 17 2013, 09:36 PM
Mike Bellis
One caviat Mike:
74 and 75 had smog equipment s... Dec 17 2013, 10:51 PM
ruby914
One caviat Mike:
74 and 75 had smog equipment ... Dec 17 2013, 10:56 PM
jeffdon Holy shit....BOTH my PORSCHE 914's have VW eng... Dec 17 2013, 09:51 PM
r_towle
Holy shit....BOTH my PORSCHE 914's have VW en... Dec 20 2013, 09:32 PM
maf914
My searching hasnt gotten me very far. Im sure mo... Dec 19 2013, 08:25 AM
garrettlee1 I'm doing the a g60 with vw Fox transmission i... Dec 21 2013, 12:20 PM
Mike Bellis
I'm doing the a g60 with vw Fox transmission ... Dec 21 2013, 01:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:30 AM |
