> Watercooled VW / Audi motor swaps?, it IS a VW afterall, right?....
2mAn
post Nov 26 2013, 12:23 AM
trying to see how long I can go without a 914
My searching hasnt gotten me very far. Im sure most of you hate the idea, and thats fine. I am in the research phase and havent done anything yet, but I am close to purchasing the 914 and want to have a solid gameplan prior to purchasing the vehicle.
SO whos done it, I know of a 20v turbo here on the board, but havent seen any others.
Thanks
-Simon
2mAn
post Dec 5 2013, 06:13 PM
bumping this back up since it looks like the Rabbit will finally be sold and the garage spot will be open for my project...
2mAn
post Dec 16 2013, 01:01 PM
BUMP
Im with you on the bellhousing side, just curious what flywheel/clutch/PP setup Id have to use. Im assuming it depends on the transmission I use, yes?
You lost me on the flanges, I know you are referring to the size that attaches to the CVs, but what size flange do the 914s have? 108mm? or 90mm?? something else??
Mike Bellis
post Dec 16 2013, 05:55 PM
Resident Electrician
QUOTE(2mAn @ Dec 16 2013, 11:01 AM) *
BUMP
I believe the stock size is 94mm. Early 911 outer stub flanges will fit in either a 100mm or 108mm flange size. it's a bolt on swap if you get the right ones. if you get the wrong ones, you need a 5mm spacer ring.
I just made some 108mm flanges for my Boxster/Passat 5 speed tranny. I chocked up the flanges in my lathe, machined off the 100mm bolt pattern and carefully welded a 108mm adapter onto the flange. I then spun it in the lathe again to check it for true. I welded it like a structural double pass weld. Good heat. Good penetration. Came out pretty god and better than expected. picture will show up in my build thread soon.
BTW, I have a set of 100mm outer flanges for sale if anyone needs them.
2mAn
post Dec 17 2013, 12:43 AM
I'll be in San Jose next week. I might even own a 914 by then. I'll PM you when Im in town
2mAn   Watercooled VW / Audi motor swaps?   Nov 26 2013, 12:23 AM
SirAndy   it IS a VW afterall, right? Actually no, the 914 w...   Nov 26 2013, 02:18 AM
2mAn   it IS a VW afterall, right? Actually no, the 914 ...   Nov 26 2013, 12:18 PM
jimkelly   most conversions here are either Porsche 6 and 91...   Nov 26 2013, 06:05 AM
Mark Henry   IIRC the engine sits too high or is too long.   Nov 26 2013, 06:46 AM
dlestep   There have been a few, here and there. Only becaus...   Nov 26 2013, 08:45 AM
gothspeed   There have been a few, here and there. Only becau...   Nov 29 2013, 02:14 PM
Mike Bellis   I think it's a great idea to install a 20v tur...   Nov 26 2013, 08:58 AM
dlestep   I think it's a great idea to install a 20v tu...   Nov 26 2013, 09:03 AM
jimkelly   http://www.914world.com/bbs2/index.php?sho...c=850...   Nov 26 2013, 09:09 AM
Cap'n Krusty   A late 90s TDi would make a nice swap ...............   Nov 26 2013, 09:51 AM
Dave_Darling   A late 90s TDi would make a nice swap ..............   Nov 26 2013, 12:29 PM
jeffdon   A late 90s TDi would make a nice swap ..............   Dec 17 2013, 04:50 PM
championgt1   Not sure if he ever finished it. http://www.914wo...   Nov 26 2013, 12:29 PM
paroxysm   Not sure if he ever finished it. http://www.914w...   Dec 31 2013, 05:05 PM
2mAn   So Ive been chatting via PM with rohar who has don...   Nov 29 2013, 01:04 PM
rohar   So Ive been chatting via PM with rohar who has do...   Nov 29 2013, 01:50 PM
Mike Bellis   Some Audi transmissions have a 100mm flange the ma...   Nov 29 2013, 02:21 PM
rohar   Given the engine at play, you could go with the Au...   Nov 29 2013, 02:58 PM
2mAn   I think Im going to have to go with the 4000 trans...   Nov 29 2013, 03:44 PM
rohar   I think Im going to have to go with the 4000 tran...   Nov 29 2013, 03:50 PM
Mike Bellis   I always thought it was neat the way all the Audi ...   Nov 29 2013, 04:26 PM
rohar   THANKS MIKE! That was kinda what I was trying...   Nov 29 2013, 05:28 PM
Mike Bellis   THANKS MIKE! That was kinda what I was tryin...   Nov 29 2013, 05:31 PM
rohar   THANKS MIKE! That was kinda what I was tryi...   Nov 29 2013, 05:38 PM
2mAn   bumping this back up since it looks like the Rabbi...   Dec 5 2013, 06:13 PM
2mAn   BUMP Im with you on the bellhousing side, just cu...   Dec 16 2013, 01:01 PM
Mike Bellis   BUMP Im with you on the bellhousing side, just c...   Dec 16 2013, 05:55 PM
2mAn   I'll be in San Jose next week. I might even ow...   Dec 17 2013, 12:43 AM
larryM   depends on your objective - PCA frowns on hybrids ...   Dec 17 2013, 03:03 PM
damesandhotrods   depends on your objective - PCA frowns on hybrids...   Dec 17 2013, 05:08 PM
2mAn   As far as a TDI goes it depends in which year. Tec...   Dec 17 2013, 06:38 PM
Rotary'14   As far as a TDI goes it depends in which year. Te...   Dec 17 2013, 07:02 PM
Mike Bellis   As far as a TDI goes it depends in which year. Te...   Dec 17 2013, 07:53 PM
2mAn   [size=3]Yes it is legal to swap an engine from an...   Dec 20 2013, 11:42 AM
914_teener   One caviat Mike: 74 and 75 had smog equipment so...   Dec 17 2013, 09:36 PM
Mike Bellis   One caviat Mike: 74 and 75 had smog equipment s...   Dec 17 2013, 10:51 PM
ruby914   One caviat Mike: 74 and 75 had smog equipment ...   Dec 17 2013, 10:56 PM
jeffdon   Holy shit....BOTH my PORSCHE 914's have VW eng...   Dec 17 2013, 09:51 PM
r_towle   Holy shit....BOTH my PORSCHE 914's have VW en...   Dec 20 2013, 09:32 PM
maf914   My searching hasnt gotten me very far. Im sure mo...   Dec 19 2013, 08:25 AM
garrettlee1   I'm doing the a g60 with vw Fox transmission i...   Dec 21 2013, 12:20 PM
Mike Bellis   I'm doing the a g60 with vw Fox transmission ...   Dec 21 2013, 01:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:21 AM
