| barefoot |
Dec 16 2013, 05:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,492 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
My ride had 5 lug adapters installed when I got the car, just got into taking the rear suspension off yesterday and took adapters off for the first time. My 5 lug bolt pattern is about 115 mm, so not standard Porsche 130 mm pattern. The adapters used one of the original holes in the hub for a longer stud, then had 4 others pressed into the adapter. How do you get 115 out of 130 using one of the hub holes ???
There I fixed it, sorry for poor proof read. here's how, an offset stud. Anyone seen any of these befiore? Spacers are 21mm thick and die cast, no idea who made them. |
| Mike Bellis |
Dec 16 2013, 06:02 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
You need to throw away you metric measuring tape. 315mm = 12.4" Bolt pattern and 121mm = 4.7" thick spacer.
Offset studs are an old cheap way to change wheels around. I would not reuse them. They look scary! |
| CG-914 |
Dec 17 2013, 01:27 AM
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California |
You need to throw away you metric measuring tape. 315mm = 12.4" Bolt pattern and 121mm = 4.7" thick spacer. Offset studs are an old cheap way to change wheels around. I would not reuse them. They look scary! Metric all the way!!!!!!!!!!! (IMG:style_emoticons/default/beer.gif) |
barefoot 5 LUG Conversions Dec 16 2013, 05:18 PM
rnellums Terrifying. Dec 16 2013, 06:00 PM
SirAndy Terrifying.
:agree: :blink: Dec 16 2013, 06:03 PM
SirAndy You need to throw away you metric measuring tape. ... Dec 16 2013, 06:04 PM
TargaToy 315.....AROUND. :D Dec 16 2013, 08:24 PM
McMark 315 = 115 + typo. :poke: Dec 17 2013, 03:12 AM
finchmunoz :shock1: Dec 17 2013, 09:52 AM
Markl Offset lugs weren't uncommon back in the day -... Dec 17 2013, 09:30 PM
barefoot
Offset lugs weren't uncommon back in the day ... Dec 20 2013, 05:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 06:15 AM |
