9590 Valve Train Setup, Valve Train Setup |
Highland |
Dec 17 2013, 12:26 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
I started setting up the valve train for a 9590 cam with 0.426" lift for both exhaust and intake. I took some pictures at half lift and like to get some verification on this is what it's suppose to look like. I know the drawn in lines are not completely valid cause the picture is not perfectly square form the side.
Also RAT specifies to be within +/-5% of cam lift. Is within 5% cylinder to cylinder also okay? If not, what is a good target? |
Mark Henry |
Dec 17 2013, 05:26 PM
If you removed .060 from the bottom of the adjuster screw hole now radius (grind, countersink) the hole so the foot swivels freely.
Jake Raby |
Dec 17 2013, 07:03 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Lo-Fi Version | Time is now: 4th June 2024 - 09:37 PM |
