billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,408 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States ![]() |
I know you can use a furniture dolly to remove the engine (I've used that method twice). However, I would prefer to have something a little better for the next time.
Last thread I could find was 2010 so figured was time to ask if anything new was available. Harbor Freight (as well as Northern Tool and other vendors) has several different jacks that may work. Since I prefer to lift the car up in the air and lower the engine with a jack, one of these may work. Does anyone have experience with these? Motorcycle lift: 1500 lb motorcycle lift Lightweight Motorcycle lift: Lightweight lift Hydraulic Table: Hydraulic Table Transmission Jack: Transmission Jack Low Profile Transmission Jack: Low Profile Transmission Jack I'm leaning towards the table but wanted to know what others have experienced. |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,635 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Bill I used a transmission jack from HF. Works great, only need to remove air box to have enough room to slide engine out from under car. I would also suggest adding a piece of wood to the plate of the jack and cut a notch out of it for where the clutch cable wheel is on the trans.
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 23rd September 2025 - 12:04 AM |
