> Starts out smooth, then what the buck?
Jesco Reient
post Dec 18 2013, 06:24 PM
When I first start the car cold for the day. (2056, D-jet, Raby 9590 cam, timing 27 advance @3500) The car has no cold start valve but has not seemed to care. First start it runs smoothly pulls away from the house shifting @ 3500 it acts nicely. After warming up for awhile as the motor reaches 3200 to 3600 it bucks severely then above 3600 it smooths out a bit. Then as it gets warmer the bucking moves down the RPM range to 2600 to 2800 RPM becoming not very drivable. any ideas out there? (IMG:style_emoticons/default/confused24.gif)
boxsterfan
post Dec 19 2013, 10:57 AM
914's are kewl
Also, how about your fuel filter? Clogged?
Or a pinched fuel line up front by the gas tank? Still running original plastic fuel lines in the tunnel or upgraded to SS?
And, as crazy as it may sound, how are all of your electrical grounds? Battery to body and transmission groundstrap are the biggies.
Jesco Reient
post Dec 19 2013, 11:46 PM
QUOTE(boxsterfan @ Dec 19 2013, 08:57 AM) *
Thanks again for the input, Original plastic lines replaced by Stainless Steel lines at the beginning of the build, I have checked all the hoses to make sure that they are smooth with no kinking. Secured the correct groundstrap to the transmission during the engine/transmission installation. I have checked the other grounds back through the harness with a Fluke Multimeter.
r_towle
"What is your valve train setup?
Aluminum or chromoly push rods?
Swivel foot or solid adjusters?
Last time you adjusted the valves?"
The valve train set up is comprised of Raby's spring eliminator spacers, Swivel foot adjusters, Chromoly pushrods, and I just adjusted the valves to zero lash prior to the start up last week. the engine has run well except for the bucking since the valaves were adjusted.
rick 918-S
"From the sounds of your last post about going through the entire F.I. and refurbishing the vacuum hoses and electrical connections I would start to suspect fuel delivery. I wonder if the fuel pump is weak. Describe the bucking. is it a miss or a stall?"
Miss could be from the spark plug wire interfering with the MAPS. Someplace around here there is some info about keeping the plug wire away from the MAPS as it will cause issues.
Stall could be from weak pump."
rick, It feels like a plug or plugs laying down, but I'm thinking with my lack of experience with the feel of the D-Jetronic injection an injector laying down could feel similar. I put a fuel pressure gauge on the driver's side fuel rail (a solid 30 PSI @ 3500 RPM) and started the engine and rechecked the timing this afternoon. The timing is now once again verified to be set to 27 degrees @ 3500. I added a new Yellow mark on the fan when the engine is at 0 Degrees TDC, This combined with my computerized timing light with 27 degrees of advance verified the timing was slightly off from yesterday. I am satisfied with the new timing and the car drove a good bit better with a slight stumble at 3400 to 3800 RPM. But still not something I'd hand over to my wife and so go have fun.
gothspeed
"The above is good advice ..... the only thing I'd add, is maybe the CHT sensor is bad or not getting a good connection."
This is next on my check list, in my research today I have found that if I have the 1974 sensor in my 1973 set up it may not act correctly, I have also found out today that there is supposed to be a resistor inline on the 1973 2.0 litre D-Jet cars that I don't have inline. Brad Mayeur has told me it needs to be a 270 Ohm resistor. That and I may attempt to swap in a different distributor and see if the problem stays the same or goes away.
The advice regarding the wideband A/F meter is interesting which one did you use? I can also check the resistance of the different sensors again and make sure they are still in specifications.
The end result is the car was barely drivable today, so I took it for a short test drive, better than yesterday but tomorrow will be a day of rest for the little car.
Thank you all for your input I'll keep you apprised of where it is at.
Jesco Reient   Starts out smooth, then what the buck?   Dec 18 2013, 06:24 PM
boxsterfan   When I first start the car cold for the day. (205...   Dec 18 2013, 06:32 PM
Jesco Reient   Could be TPS worn, trigger points on dizzy or fu...   Dec 18 2013, 07:57 PM
boxsterfan   Also, how about your fuel filter? Clogged? Or a ...   Dec 19 2013, 10:57 AM
Jesco Reient   Also, how about your fuel filter? Clogged? Or a...   Dec 19 2013, 11:46 PM
r_towle   r_towle "What is your valve train setup? Al...   Dec 20 2013, 10:48 AM
r_towle   What is your valve train setup? Aluminum or chromo...   Dec 19 2013, 12:13 PM
rick 918-S   From the sounds of your last post about going thro...   Dec 19 2013, 03:44 PM
gothspeed   The above is good advice ..... the only thing I...   Dec 19 2013, 08:18 PM
rmital   The above is good advice ..... the only thing I...   Dec 19 2013, 08:36 PM
Mike Bellis   What everyone is eluding to here is you have a lea...   Dec 19 2013, 08:29 PM
gunny   I had the same type of issue and after about a yea...   Dec 19 2013, 08:29 PM
914GT   Maybe try retarding the timing a few degrees and s...   Dec 19 2013, 09:16 PM
r_towle   Runs good cold, run worse when hot. Metal expands ...   Dec 19 2013, 09:40 PM
rick 918-S   Runs good cold, run worse when hot. Metal expands...   Dec 19 2013, 10:28 PM
Jesco Reient   Runs good cold, run worse when hot. Metal expand...   Dec 20 2013, 08:41 AM
rick 918-S   You may want to re-run a test on your MAPS too jus...   Dec 20 2013, 06:42 AM
gunny   http://www.aemelectronics.com/wideband-air...-fuel...   Dec 20 2013, 07:15 AM
boxsterfan   http://members.rennlist.com/pbanders/DJetP...tm#tr...   Dec 20 2013, 10:44 AM
rhodyguy   have you calibrated the tps using a proper plug, j...   Dec 20 2013, 11:22 AM
Jesco Reient   have you calibrated the tps using a proper plug, ...   Jan 22 2014, 06:59 PM
rmital   ............As suggested I tried running the head...   Jan 23 2014, 11:28 AM
Jesco Reient   ............As suggested I tried running the hea...   Jan 23 2014, 02:44 PM
gunny   If the issue is RPM sensitive and not throttle pos...   Dec 20 2013, 11:40 AM
Jesco Reient   If the issue is RPM sensitive and not throttle po...   Dec 20 2013, 04:23 PM
Jesco Reient   Today has been a research and reading day, letting...   Dec 20 2013, 04:22 PM
Java2570   I've seen a lot of other threads with folks us...   Jan 23 2014, 07:54 AM
mepstein   I had bucking sometimes and a perfect running engi...   Jan 23 2014, 09:09 AM
Jesco Reient   I had bucking sometimes and a perfect running eng...   Jan 23 2014, 09:37 AM
r_towle   I had bucking sometimes and a perfect running en...   Jan 23 2014, 01:37 PM
Jesco Reient   OK, todays test drive revealed a nice smooth pull ...   Jan 23 2014, 07:55 PM
- Lo-Fi Version Time is now: 11th March 2026 - 04:25 AM
