rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
2.2 stuff. what are the values?
Attached thumbnail(s) ![]() ![]() ![]() ![]() |
rhodyguy |
box #
Attached thumbnail(s) ![]() |
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,417 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
box # 2.2 and 2.4 engines have the same bore but different compression ratios. I know some people and I have swapped out the 2.4 pistons for the 2.2 pistons to give yourself a few more hp. I looked up the part # on the box that you have. The closest thing that I found with the part # was used as a 2.4 T p/c set (non cis). If you look inside the piston you will see some letters/numbers this will confirm what you have. Look at the list attached to see what you have. Your best bet would be to figure out what you have then list them on the Pelican site. I've had better luck selling 911 p/c's there. Attached File(s) ![]() |
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,926 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
box # 2.2 and 2.4 engines have the same bore but different compression ratios.I know some people and I have swapped out the 2.4 pistons for the 2.2 pistons to give yourself a few more hp. I looked up the part # on the box that you have. The closest thing that I found with the part # was used as a 2.4 T p/c set (non cis). If you look inside the piston you will see some letters/numbers this will confirm what you have. Look at the list attached to see what you have. Your best bet would be to figure out what you have then list them on the Pelican site. I've had better luck selling 911 p/c's there. |
Luke M |
box # 2.2 and 2.4 engines have the same bore but different compression ratios.I know some people and I have swapped out the 2.4 pistons for the 2.2 pistons to give yourself a few more hp. I looked up the part # on the box that you have. The closest thing that I found with the part # was used as a 2.4 T p/c set (non cis). If you look inside the piston you will see some letters/numbers this will confirm what you have. Look at the list attached to see what you have. Your best bet would be to figure out what you have then list them on the Pelican site. I've had better luck selling 911 p/c's there. Yup, I knew that the stoke was different (66 vs 70.4) that's why I said that the bore is the same between 2.2 &2.4 other then compression ratio. Put the 2.2 pistons in a 2.4 engine and you get a few more hp. Good upgrade for someone that's rebuilding a 2.4 and wants a little more out of it. |
Lo-Fi Version | Time is now: 31st August 2025 - 02:24 AM |
