> Rusty bucket into Solo toy, Some highlights of my budget autocross build from rust to rocket
Han Solo
post Sep 30 2013, 10:40 AM
Post #241
New to this forum but I've been around 944s, 924Ss, Boxster and Cayman forums for years.
This one is going to take some time. Purchased for $900, non-running but otherwise complete '73 914 2.0. Certainly just beyond a viable restoration car but probably okay for what I plan to do with it. Here's some highlights of the tear down...
On the trailer going to the house.
Han Solo
post Dec 22 2013, 05:57 PM
Post #242
And indeed I did change my plan for this troublesome area. After looking hard, I determined that trying to lap one long piece was going to be really difficult. I couldn't figure out how to really do that with all the little bends and the fact that the mount for the brake master cylinder is a little half box. I watched this YouTube video by Restoration Design and that really helped me get a good idea of what was missing... https://www.youtube.com/watch?v=3kMOMNhxg-A
So, I cut a 4" x 22" strip and then trimmed a right angle space where the tunnel joins on the right side in the old metal. The new strip was then cut four times to make flaps. The narrow flap on the left (bent up) passes between the suspension mount and the brake cylinder area (bent down). There's a large notch for the suspension mount and then a remaining flap on the extreme left to join with the wheel house. After welding this large strip in place, I fabricated a half box to lay over the brake cylinder mount. I marked the the two bolt holes, the large hole and cut those out. Then I trimmed off the sides, fixed that into place with a couple nuts and bolts and welded that in. Continuing to work from right to left, I welded around the suspension mount (front and back) and finished by tying in the wheel house and this new piece. That was the most complex with three different planes all joining and a odd curve in the wheel house. I'll do more welding and dressing in that area when I put the floor pan on. Many of the welds were impossible to grind off due to the tight quarters. I was able to weld much of the top joint front and back which should add strength. You'll see the original cylinder mount still in place behind the new metal but I should be able to carefully cut that out once I confirm correct master cylinder positioning. Interesting thing about the area is it is a part of the floor pan. The Porsche diagrams show that from the firewall forward to the front of the front trunk (including the bend over the steering rack) is ALL floor pan.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1387756671.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1387756672.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1387756672.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1387756672.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1387756673.5.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1387756673.6.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1336.photobucket.com-16456-1387756673.7.jpg)
Han Solo   Rusty bucket into Solo toy   Sep 30 2013, 10:40 AM
Han Solo   The front pan is just a tad rusty.   Sep 30 2013, 10:42 AM
Han Solo   I've seen worse interiors but there's ants...   Sep 30 2013, 10:44 AM
Han Solo   Floor pans are a little rough too.   Sep 30 2013, 10:47 AM
Han Solo   There's daylight under those peddles.   Sep 30 2013, 10:48 AM
Han Solo   Rear trunk pan is toast also.   Sep 30 2013, 10:51 AM
Han Solo   My hillbilly car lift before dropping the engine a...   Sep 30 2013, 10:53 AM
Han Solo   I got over my fear of spiders while dropping this....   Sep 30 2013, 10:56 AM
Han Solo   And now it gets really ugly. Seller showed me he c...   Sep 30 2013, 10:58 AM
Woody   And now it gets really ugly. Seller showed me he ...   Sep 30 2013, 11:08 AM
914itis   My hillbilly car lift before dropping the engine ...   Dec 5 2013, 12:31 PM
Han Solo   My hillbilly car lift before dropping the engine...   Dec 5 2013, 01:02 PM
914itis   [quote name='914itis' post='1966570' date='Dec 5 ...   Dec 5 2013, 01:13 PM
SirAndy   I vote for tube-frame ... :D :wttc:   Oct 1 2013, 11:37 AM
Han Solo   I vote for tube-frame ... :D :wttc: It may c...   Oct 1 2013, 11:46 AM
Han Solo   Pulled the fuel tank yesterday. More rust around t...   Oct 2 2013, 10:35 AM
Han Solo   Moving on to rear trunk. Stripped and rust killed ...   Oct 10 2013, 01:17 PM
Han Solo   Continuing the rear trunk pan cut out. http://www...   Oct 21 2013, 07:44 AM
Han Solo   I finished up the rear trunk pan cut out but was u...   Oct 29 2013, 07:46 AM
BMXerror   Lookin good! And nice trailer! :headbange...   Oct 29 2013, 08:31 PM
Han Solo   Moved back to the rear trunk pan. Welding the cros...   Nov 7 2013, 01:10 PM
Han Solo   Welding completed in rear trunk pan. After grindin...   Nov 9 2013, 06:48 PM
Han Solo   With the rear trunk somewhat completed, I'm wo...   Nov 20 2013, 08:32 AM
Han Solo   Back at it tonight. I revisited the passenger side...   Nov 22 2013, 08:52 PM
mepstein   Door beams, bracing?   Nov 22 2013, 09:05 PM
Han Solo   Although recommended by many, I'm not using br...   Nov 24 2013, 08:18 AM
Han Solo   More welding shots. Getting better at this :) h...   Nov 24 2013, 08:20 AM
Han Solo   Moving on to the drivers side inner clam shell. h...   Nov 26 2013, 12:29 PM
Han Solo   Great progress today. I got the drivers side inner...   Dec 1 2013, 07:04 AM
Han Solo   I had a couple hours this evening to move on to th...   Dec 5 2013, 09:28 AM
Han Solo   Another few hours of tunnel fun this afternoon. I ...   Dec 5 2013, 09:32 AM
Han Solo   Despite the extreme cold in the garage, I'm ba...   Dec 7 2013, 12:34 PM
Han Solo   So I'm cutting back towards the firewall from ...   Dec 8 2013, 04:00 PM
Han Solo   A bit more progress last night. That little odd sh...   Dec 14 2013, 08:08 PM
Han Solo   The plan on the drivers side of the tunnel is to l...   Dec 14 2013, 08:12 PM
Han Solo   I started the morning off with marine clean and th...   Dec 14 2013, 08:17 PM
Han Solo   So I'm diving in to this last area of floor pa...   Dec 19 2013, 06:47 AM
Han Solo   And indeed I did change my plan for this troubleso...   Dec 22 2013, 05:57 PM
ThePaintedMan   Looking good so far! One thing I noticed - th...   Dec 23 2013, 01:06 PM
Han Solo   Looking good so far! One thing I noticed - t...   Dec 23 2013, 05:59 PM
Han Solo   Today I got the upper pad, lower pad, steering whe...   Dec 23 2013, 06:22 PM
Han Solo   A great day off for Christmas eve and I'm craw...   Dec 24 2013, 06:49 PM
Han Solo   The wife ran me out of the house while Christmas d...   Dec 26 2013, 08:48 AM
Han Solo   Another evening of patching fun. Finished up the p...   Dec 27 2013, 10:26 AM
Han Solo   Outstanding progress today! I've got POR 1...   Dec 28 2013, 10:08 PM
J P Stein   Ayup, a race car don't need much in the way of...   Dec 29 2013, 12:54 AM
Han Solo   Ayup, a race car don't need much in the way o...   Dec 29 2013, 08:53 AM
Han Solo   Well I took a good look at the drivers side long a...   Dec 29 2013, 04:48 PM
ONTHEGRIND   Looking good keep uo the hard work.   Dec 29 2013, 06:15 PM
Han Solo   It seems that the firewall in this car progressive...   Jan 2 2014, 08:48 AM
IGTARD   :bump: :bump: :bump: :bump: Nice :shades2: :sh...   Jan 3 2014, 02:43 AM
Han Solo   Another patch done at the center of the firewall a...   Jan 3 2014, 12:20 PM
Han Solo   Before... http://www.914world.com/bbs2/uploads_of...   Jan 4 2014, 07:40 PM
Han Solo   Last day of mild weather here so I'm back out ...   Jan 5 2014, 06:37 PM
Han Solo   It finally warmed up enough Thurs. for me to get a...   Jan 11 2014, 09:18 PM
Han Solo   Back at it today and at first I'm focusing on ...   Jan 12 2014, 06:30 PM
J P Stein   My cage builder would be me. I did it twice. Runni...   Jan 13 2014, 08:53 AM
J P Stein   I did start with a a car as rust free as possible ...   Jan 13 2014, 09:01 AM
Han Solo   Last night's patch was tough. The battery tray...   Jan 15 2014, 08:46 PM
CptTripps   Dude...you're killing it. It's a lot of H...   Jan 16 2014, 08:05 AM
f1rocks   Where are you in middle Tennessee?   Jan 16 2014, 11:54 AM
Han Solo   Where are you in middle Tennessee? Near Lebanon...   Jan 18 2014, 09:43 PM
f1rocks   Near Lebanon TN. About seven miles from the track...   Jan 27 2014, 10:00 AM
Han Solo   Near Lebanon TN. About seven miles from the trac...   Jan 28 2014, 01:15 PM
f1rocks   I haven't made it to the cars and coffee. Tha...   Jan 28 2014, 03:54 PM
ablesnead   This thread is driving me nuts...I mean ...jeez b...   Jan 16 2014, 04:07 PM
Han Solo   This thread is driving me nuts...I mean ...jeez ...   Jan 18 2014, 09:53 PM
J P Stein   I paid 4500 bucks for that green car back in the l...   Jan 17 2014, 09:23 AM
Han Solo   So today I did the small patch under the long. Thi...   Jan 18 2014, 09:57 PM
J P Stein   Well, if you must....... You are into an area that...   Jan 19 2014, 09:34 AM
Han Solo   Definitely want your input and advise JP. I can se...   Jan 19 2014, 02:22 PM
Han Solo   This next patch is going to be REALLY tough. It...   Jan 19 2014, 02:43 PM
J P Stein   I removed the 4 banger engine mounts when I put in...   Jan 19 2014, 09:49 PM
Cupomeat   :agree: I was just thinking that myself, that you...   Jan 20 2014, 09:11 AM
Han Solo   MLK day and I've got four hours to do this mon...   Jan 20 2014, 08:19 PM
Han Solo   I've been thinking about how to make a jig for...   Jan 25 2014, 04:11 PM
Han Solo   Fabulous weather today and I put a few hours into ...   Jan 26 2014, 08:29 PM
Han Solo   Engine compartment mostly done. Before... http:/...   Feb 1 2014, 11:03 PM
Han Solo   I've been working for this for a long time. Ge...   Feb 2 2014, 08:27 PM
Han Solo   Installing the front floor pan took about 8 hours....   Feb 8 2014, 09:16 PM
Han Solo   I'm about 4 hours into the rear pan install an...   Feb 13 2014, 12:35 PM
Han Solo   I never thought I'd get so much gratification ...   Feb 16 2014, 08:56 PM
Han Solo   I had the day off and was able to get the right fr...   Feb 17 2014, 07:48 PM
nukepipe   Keep going dude!!! Love to see it ru...   Feb 17 2014, 08:09 PM
Han Solo   Before I lower the car, strip and treat the gas ta...   Feb 22 2014, 07:19 PM
Han Solo   I got the car re-hung last Sunday and started prep...   Feb 27 2014, 12:04 PM
J P Stein   I just had my new Lincoln welder puke......4 month...   Feb 28 2014, 08:15 AM
Han Solo   Not trying to be a hard ass, but your welding is...   Feb 28 2014, 09:22 AM
Alphaogre   Having a MIG welder with gas will be a huge help a...   Feb 28 2014, 12:41 PM
Han Solo   Just an update... Looks like it will be hands off...   Mar 5 2014, 08:55 AM
Han Solo   It was nice to get into the project yesterday and ...   Mar 18 2014, 09:04 PM
Han Solo   Finally got around to that small area under the cl...   Mar 20 2014, 08:19 AM
Han Solo   This evening brings the end of a very productive w...   Mar 23 2014, 06:51 PM
Han Solo   I am sure glad I waited to tackle the right front ...   Mar 23 2014, 06:55 PM
Han Solo   Last couple of evenings I've been working on t...   Mar 26 2014, 08:36 PM
Han Solo   Beside the replacement fender there was a rust thr...   Mar 28 2014, 06:23 AM
Han Solo   Blazing ahead. During the week I stripped the dono...   Mar 29 2014, 07:33 PM
Han Solo   Last two evenings I've been pulling the all th...   Apr 1 2014, 08:03 PM
jaxdream   This thread reminds me of Veltor's 914 over in...   Apr 2 2014, 09:18 AM
Han Solo   I am glad to have these front fenders treated. The...   Apr 5 2014, 06:49 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 16th June 2024 - 09:23 PM
