| Elliot Cannon |
Jan 6 2014, 05:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
After getting my heads rebuilt I am Finally getting around to putting my engine back together. Can anyone recommend a good (easy) way to clean the carbon deposits off the heads? Can this be done OK without removing the cylinders?
| Matt Romanowski |
Jan 7 2014, 09:38 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
McMark is right. If you're not taking it all the way apart, leave it alone. You're only going to get more crap in the motor and oil. That is not an excessive amount of carbon and will be back after about 10 minutes of running.
Elliot Cannon Cleaning carbon Jan 6 2014, 05:28 PM
SLITS Put it back together ... fire it up and pour a cup... Jan 6 2014, 05:57 PM
r_towle
Put it back together ... fire it up and pour a cu... Jan 6 2014, 06:34 PM
Elliot Cannon
Put it back together ... fire it up and pour a cu... Jan 6 2014, 08:23 PM
jeffdon
Put it back together ... fire it up and pour a c... Jan 6 2014, 09:37 PM
jimkelly is oven cleaner NOT safe ? Jan 6 2014, 06:29 PM
76-914 :agree: w/ Schlitz. squirting it in with a bottle ... Jan 6 2014, 07:24 PM
Elliot Cannon
:agree: w/ Schlitz. squirting it in with a bottle... Jan 6 2014, 08:20 PM
yeahmag Water does work, but a squirt bottle works better.... Jan 6 2014, 08:32 PM
r_towle High pressure steam cleaning.
Google it, it has wo... Jan 6 2014, 08:37 PM
euro911 We use to de-carbonize using water while on a dyno... Jan 6 2014, 08:43 PM
SLITS
We use to de-carbonize using water while on a dyn... Jan 6 2014, 08:55 PM
r_towle My concern with any type of wire wheel is all my w... Jan 6 2014, 09:00 PM
StratPlayer http://www.orisonmarketing.com/pistonkleen.html Jan 6 2014, 09:06 PM
SLITS Ok Av8tor .... The water hitting the hot cylinder ... Jan 6 2014, 09:47 PM
McMark Why bother? Or are you planning on tearing down t... Jan 7 2014, 01:34 AM
Elliot Cannon
Why bother? Or are you planning on tearing down ... Jan 7 2014, 02:12 AM
ConeDodger
Why bother? Or are you planning on tearing down... Jan 7 2014, 06:58 AM
Mark Henry As a builder I've never liked the water trick.... Jan 7 2014, 09:29 AM
Bartlett 914 While you are in there,do clean what will easily c... Jan 7 2014, 09:59 AM
ruby914 http://www.ppg.com/coatings/aerospace/coat...bon_R... Feb 6 2014, 08:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:42 PM |
