rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,245 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
right on it's nose. for starters the linkage was on the wrong end of the carbs. at least for me. the draw was equal at ldle. did the back off the pass side idle speed screw and the pass side fell about one half compared to the dr side. tried to adjust the pass side droplink with my head upside down and both hands jammed behind the pass carb. OWWW, my neck. enough for the day. shower, couch, aspirin, heating pad. apparently the previous mechanic thought the best way to ensure there were no vacuum leaks was to use cut steel lock washers everywhere and continue to tighten every nut to the point i had to lean on them a bit to loosen. filthy, filthy, filthy. gaskets were garbage. every one had to be scraped to get them off most surfaces after phase one of the exterior cleaning.
shiny. had to swap the arms for the drop links end to end so they worked with the linkage going to the front of the carbs. replaced the idle air mixture screw o-rings, hard and squished flat, and went thru the initial baseline setup. note the hi-tech bamboo measurement tool for the correct settings for the accelerator pump rods. Triad linkage is in temporarily place and will button it up tomorrow. drop links in the open out front. right where i like them. Attached thumbnail(s) ![]() ![]() ![]() ![]() ![]() ![]() |
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
It is amazing what you find sometimes. Now I am not saying that someone won't come back and look at some of my repairs and wonder why I did certain things. But if you check my bolts they will at least be all metric and the appropriate gaskets used. We all have made repairs that are temporary in nature and taken a lot of time to get back to them but it seems like just when you think you have seen it all, then something new pops up.
Kevin I will drop mine off to you next week for a QC check and will include the heating pad! |
Lo-Fi Version | Time is now: 4th June 2025 - 05:43 PM |
