> Oil pressure even bigger idiot light
ThePaintedMan
post Jan 13 2014, 09:21 PM
At some point I'll be modifying my dash to put my additional gauges in plain view with the rest of them, as Chris Foley suggested to me some time ago. While I'm at it, I'd like to put an additional oil pressure idiot light up top with a modern LED bulb to get the driver's attention (even though at race pace, by the time it come's on the damage will probably already have been done). Is it simple enough to just piggy-back onto the existing oil pressure light in the fuel gauge, splicing into those wires?
Ideally it would be nice to do the same thing with the alternator light, but given the fact that it's part of the charging system, I don't think I don't think I can do that, correct?
ThePaintedMan
post Jan 13 2014, 10:09 PM
Thanks Doug - that came out really nice! So since you have aftermarket gauges, you just used the original wiring for the existing idiot lights? I'm intending to leave the original gauges in, retaining the alt and oil pressure lights, but adding two more at the very top of the dash. Does that make sense?
mrbubblehead
post Jan 13 2014, 10:17 PM
Twodollardoug
QUOTE(ThePaintedMan @ Jan 13 2014, 08:09 PM) *
yes the og wiring for the idiot light. for the alternator i left the original alt bulb and holder and wired the LED in parallel with the old bulb and its holder. i think i might have soldered a ground wire to old bulb holder to complete the circuit. make sense? i did wrap the old bulb in black tape so it wouldnt illuminate the back of the pod.
AE354803
post Jan 13 2014, 11:20 PM
QUOTE(mrbubblehead @ Jan 13 2014, 08:17 PM) *
Why not wire the oil pressure idiot light to cut power to the coil?
You would need to add a bypass to supply power during starting, just a thought
- Lo-Fi Version Time is now: 2nd April 2026 - 12:33 PM
