Steering wheel hard in turns, Update: The solution was alignment |
ndfrigi |
Jan 15 2014, 01:43 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Hi, Can I get some suggestions/comments on how can I improve my steering wheel during turns.
Currently my front tires are 185x65x15. Front wheels looks very straight facing the car from front view, No issue or force to left or right when driving straight. Pretty much no issue also when running 65 to 85 mph (offcourse I only drive more than 65mph when I just follow the flow of the traffic here in California). Do I need to remove the steering rack for complete clean up or re-greasing? Thank you in advance and God Bless! Noel |
Dave_Darling |
Jan 15 2014, 01:51 PM
The joints in the steering column could be binding up. We have seen that, particularly if the steering system has been worked on recently.
Evidently you can loosen the bolts that hold the universal joints onto the steering column pieces, and move them just a little bit. Tighten the bolts and see if that helps. Another possibility is that you have too much caster angle. --DD |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:53 PM |
