Removing that dreaded bolt inner end of tie rod, Got it done |
barefoot |
Jan 15 2014, 07:11 PM
Senior Member Group: Members Posts: 1,282 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Somewhere recently someone had the same problem but I can't fine old post after several searches.
Well anyway, today I'm freshening up the front end and had to get that bolt out. Too little clearance regardless of rack position. i finally did some minor bodywork to provide more room to remove bolt, used long 1/2 extension bar and hammer to "adjust" body clearance and got the bolt out. Determined that the bolt used had about 3 more threads than needed, so a little grinding to shorten it for easy installation now. One side done, don't think i can get a grinding wheel in on other side to shorten bolt overhang but will have a look. Anyone else had this experience ?? Also saw that the aft end of torsion bar had some abrasion wear about 1" from beginning of spline, so I polished this off smooth and repainted bar. Some PO had not replaced the rear seal so I don't know if this helps keep bar centralized. New seals ordered now and I will relieve rear opening in housing to insure clearance. Many years ago I suffered a broken torsion bar due to corrosion pitting induced stress fracture in a 70 teener i had way back, so I'm careful to insure bar is very smooth and well painted. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:32 PM |
