| jrrhdmust |
Jan 15 2014, 11:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,416 Joined: 12-October 11 From: Alabama Member No.: 13,668 Region Association: None |
So I decided i would start drilling the holes for my Tarret front sway bar. I had downloaded the instructions from Pelican parts read through them a few times. I cut out the template and marked my holes. I drilled the bottom hole, and got the bright idea, that I would put bolts in the Tarret backing plate to verify and check my holes.
Much to my surprise my hole was wrong....then it dawned on me the Pelican parts instructions were for a stock sway bar...mine was Tarrett... (IMG:style_emoticons/default/headbang.gif) So now my 2 minute hole is going to cost me about 4 hours of welding and grinding to build a tiny plate to weld the hole shut.... (IMG:style_emoticons/default/headbang.gif) And all i had to do was match the template to the part and save me all of the trouble..... (IMG:style_emoticons/default/blink.gif) |
| jpnovak |
Jan 16 2014, 01:46 PM
They call me "Nanoman" ![]() ![]() Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
Bummer. Sounds like your template did not print to size. The Tarrett and stock factory mounts are the same dimension. The through body sway bars are all the same for 911, 912 and 914.
jrrhdmust Tarret Sway Bar install Jan 15 2014, 11:09 AM
Harpo I also have the Tarret sway bar and I also used th... Jan 15 2014, 06:32 PM
jrrhdmust The template from pelican is larger - like a 1/2 i... Jan 16 2014, 08:54 AM
Eric_Shea I don't think I'd worry about it, when you... Jan 16 2014, 04:03 PM
jrrhdmust Ding ding ding we have a winner, the template didn... Jan 17 2014, 12:11 PM
SirAndy Ding ding ding we have a winner, the template didn... Jan 17 2014, 01:05 PM
r_towle where to start...
Your first mistake was reading ... Jan 17 2014, 03:32 PM
Socalandy
So I decided i would start drilling the holes for... Jan 17 2014, 10:57 PM
sixnotfour drop it down another 1/4 to insure no rubbing on g... Jan 17 2014, 11:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th October 2026 - 09:34 PM |
