| jeeperjohn56 |
Jan 16 2014, 05:56 PM
Member ![]() ![]() Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Okay guys, need to install a passenger side mirror on my white car and don't want to screw up the door. Does anybody have the measurement on where too put it? This will be a stock 914 mirror. Any picture's would be appreciated. Thanks John (IMG:style_emoticons/default/driving.gif)
| dlkawashima |
Jan 16 2014, 08:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Like Jim said, I would remove the door panel, locate the two nuts that are welded in place, and stick a punch through each hole to create little pimples on the outside door skin.
BTW, this question has been asked before and the punch that's most often recommended is one of those automatic center punches that you can find at any hardware store, or even Amazon. You won't have to swing a hammer in a confined space if you use an automatic punch. When drilling, I recommend starting with a small bit and work your way up to the size you need to fit the screws through the holes. http://www.amazon.com/TEKTON-6580-Automati...h+spring+loaded (IMG:http://www.914world.com/bbs2/uploads_offsite/ecx.images-amazon.com-12234-1389925413.1.jpg) |
jeeperjohn56 Installing passenger side mirror Jan 16 2014, 05:56 PM
type47 Take the door panel off and find the nuts for the ... Jan 16 2014, 06:23 PM
toolguy IIRC, the nuts are already welded inside the door ... Jan 16 2014, 06:24 PM
McMark In exactly the same place as the driver's side... Jan 16 2014, 07:23 PM
PanelBilly HF has the punches for a couple of bucks and if th... Jan 16 2014, 08:32 PM
sfrenck I did mine last fall. The nuts are there - I just... Jan 17 2014, 07:34 AM
worn
Okay guys, need to install a passenger side mirro... Jan 17 2014, 11:24 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:42 PM |
