| cvdmolen |
Jan 18 2014, 10:50 AM
Newbie ![]() Group: Members Posts: 23 Joined: 2-April 12 From: Wageningen, NL Member No.: 14,329 Region Association: Europe |
Ok, here it goes. I bought a 914 1970, EU 1.7 D-jetronic. Off course it didn't run. I did some work on the car & engine -> other topic
But I don't get it to run smoot. I'm not an idiot with these engines, now how they love to have no vacuum leaks, valve adjustment etc etc. I've read a whole lot of bowlsby pages and every other article I could find on the net. But she just doesn't run smooth. What I know for sure: - valves / adjustment / compression -> OK - trigger points and adjustment -> OK - wiring -> OK - injectors checked -> OK - tried different Ecu's -> no difference - tried different MPS -> no difference What doesn't work: She starts, but I've the feeling that she runs on 2.5 cilinders. Lack of power except, sometimes around 2000rpm, she flys Sometimes she runs good, and all of a sudden, crappy. Where to start? Anyone nows these symptoms? And NO I don't want a carb!!!!! |
| Cap'n Krusty |
Jan 18 2014, 12:03 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
W8CC is the wrong plug, but I doubt that's your problem. W7CC or B6ES are the 2 correct plugs. There are resistor versions, and they're OK, too. I suspect that "OK" wiring harness isn't OK, and that you may have a bad ground. Jeff Bowlsby does a nice job with harnesses.
You don't say you replaced the injector seals, but you need to ensure they're in good condition. The Cap'n |
cvdmolen SOLVED - Question for a D-jetronic FI master / scientist / lover Jan 18 2014, 10:50 AM
JawjaPorsche Fuel filter? Check plug gap. New plugs? Use NGK... Jan 18 2014, 10:55 AM
cvdmolen
Fuel filter? Check plug gap. New plugs? Use NG... Jan 18 2014, 11:00 AM
mepstein check timing Jan 18 2014, 11:17 AM
Java2570 When you checked the fuel injectors, did you check... Jan 18 2014, 11:56 AM
Bleyseng also re-check the spark plug wires that they are i... Jan 19 2014, 04:55 AM
cvdmolen Tnx for all the good tips guys!
Problem solve... Jan 19 2014, 11:31 AM
bdstone914 I have many good sets of used trigger points. ... Jan 20 2014, 03:45 PM
cvdmolen
I have many good sets of used trigger points. ... Jan 21 2014, 04:01 PM
Cap'n Krusty Good luck finding new trigger points ................ Jan 20 2014, 12:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th March 2026 - 07:10 AM |
