> SOLVED - Question for a D-jetronic FI master / scientist / lover, Can't get it to run smoot, yet!
cvdmolen
post Jan 18 2014, 10:50 AM
Region Association: Europe
Ok, here it goes. I bought a 914 1970, EU 1.7 D-jetronic. Off course it didn't run. I did some work on the car & engine -> other topic
But I don't get it to run smoot. I'm not an idiot with these engines, now how they love to have no vacuum leaks, valve adjustment etc etc. I've read a whole lot of bowlsby pages and every other article I could find on the net. But she just doesn't run smooth.
What I know for sure:
- valves / adjustment / compression -> OK
- trigger points and adjustment -> OK
- wiring -> OK
- injectors checked -> OK
- tried different Ecu's -> no difference
- tried different MPS -> no difference
What doesn't work:
She starts, but I've the feeling that she runs on 2.5 cilinders.
Lack of power except, sometimes around 2000rpm, she flys
Sometimes she runs good, and all of a sudden, crappy.
Where to start? Anyone nows these symptoms? And NO I don't want a carb!!!!!
cvdmolen
post Jan 19 2014, 11:31 AM
Tnx for all the good tips guys!
Problem solved: the trigger points in the distributor, one side worked, the other didn't, maybe at higher revs sometimes. Time for new ones (IMG:style_emoticons/default/smile.gif) cleaned them, installed the bracket and *&%*(% Yeah -> smooth testdrive.
About the spark plugs, I'll order the correct ones! I thought as VW man, that they run on the same as the VW's...... W8CC
Grtz from the Netherlands
- Lo-Fi Version Time is now: 18th March 2026 - 07:11 AM
