> Flywheel Pilot Bearing, Question
jim_hoyland
post Jan 22 2014, 02:54 PM
Get that VIN ?
I previously acquired all the parts for a clutch replacement: flywheel, pressure plate, clutch, throw out bearing, and the clips, seals, bolts, washers, and bushing that go along with the main parts.
Two questions:
1. I have two clutch disks, a 6 spring and a 4 spring. Which would be preferred for street driving ?
2. I do not have a new flywheel pilot bearing; should I buy one before I start. And, would a VW parts house carry them.
Car is going in next week to replace everything, just want to have all the parts on-hand
SLITS
post Jan 22 2014, 03:55 PM
"This Utah shit is HARSH!"
Ok Jim,
The 4 spring was for the /4. Supposedly they don't make the 4 spring anymore and it was replaced by the 6 spring which was originally for the /6. The 6 spring gives a smoother take up (engagement) of the clutch. Use the 6 spring.
If the pilot bearing is still good there is no need to change it. It should run smoothly when a pilot shaft (or your finger if it's small enough) is used to rotate in it.
jim_hoyland   Flywheel Pilot Bearing   Jan 22 2014, 02:54 PM
SLITS   Ok Jim, The 4 spring was for the /4. Supposedly ...   Jan 22 2014, 03:55 PM
gunny   You need a new pilot bearing to go with your new f...   Jan 22 2014, 04:55 PM
Jon H.   I got a few engine parts from the local VW shop, t...   Jan 22 2014, 04:59 PM
Mark Henry   The pilot bearing is a pretty standard part, VW ty...   Jan 22 2014, 05:15 PM
jim_hoyland   Thank's for the tips. All the parts are new; ...   Jan 22 2014, 07:05 PM
bdstone914   Thank's for the tips. All the parts are new; ...   Jan 22 2014, 09:30 PM
Mark Henry   Thank's for the tips. All the parts are new;...   Jan 22 2014, 10:16 PM
jim_hoyland   [quote name='jim_hoyland' post='1987191' date='Ja...   Jan 23 2014, 08:14 AM
OU8AVW   [quote name='jim_hoyland' post='1987191' date='J...   Jan 23 2014, 08:49 AM
Steve Pratel   Got any tips on installing the pilot bearing? I t...   Jan 24 2014, 01:56 PM
Dave_Darling   No heat needed, it should just slip in. I think i...   Jan 23 2014, 09:50 AM
sean_v8_914   i see lots of cars missing the spacer that lives i...   Jan 23 2014, 12:13 PM
reharvey   i see lots of cars missing the spacer that lives ...   Jan 24 2014, 07:44 PM
jim_hoyland   Still need the M12 x 1.5 flywheel bolts, 25mm ? Au...   Jan 23 2014, 03:04 PM
bdstone914   Still need the M12 x 1.5 flywheel bolts, 25mm ? A...   Jan 24 2014, 12:53 PM
jim_hoyland   Still need the M12 x 1.5 flywheel bolts, 25mm ? ...   Jan 24 2014, 06:56 PM
Dave_Darling   The flywheel bolts are special parts, not standard...   Jan 24 2014, 01:54 PM
- Lo-Fi Version Time is now: 15th September 2026 - 01:31 PM
