> Flywheel Pilot Bearing, Question
jim_hoyland
post Jan 22 2014, 02:54 PM
Get that VIN ?
I previously acquired all the parts for a clutch replacement: flywheel, pressure plate, clutch, throw out bearing, and the clips, seals, bolts, washers, and bushing that go along with the main parts.
Two questions:
1. I have two clutch disks, a 6 spring and a 4 spring. Which would be preferred for street driving ?
2. I do not have a new flywheel pilot bearing; should I buy one before I start. And, would a VW parts house carry them.
Car is going in next week to replace everything, just want to have all the parts on-hand
gunny
post Jan 22 2014, 04:55 PM
You need a new pilot bearing to go with your new flywheel. Don't skip the little things, it's not easy to get the old one out undammaged and then install in new flywheel.
jim_hoyland   Flywheel Pilot Bearing   Jan 22 2014, 02:54 PM
SLITS   Ok Jim, The 4 spring was for the /4. Supposedly ...   Jan 22 2014, 03:55 PM
gunny   You need a new pilot bearing to go with your new f...   Jan 22 2014, 04:55 PM
Jon H.   I got a few engine parts from the local VW shop, t...   Jan 22 2014, 04:59 PM
Mark Henry   The pilot bearing is a pretty standard part, VW ty...   Jan 22 2014, 05:15 PM
jim_hoyland   Thank's for the tips. All the parts are new; ...   Jan 22 2014, 07:05 PM
bdstone914   Thank's for the tips. All the parts are new; ...   Jan 22 2014, 09:30 PM
Mark Henry   Thank's for the tips. All the parts are new;...   Jan 22 2014, 10:16 PM
jim_hoyland   [quote name='jim_hoyland' post='1987191' date='Ja...   Jan 23 2014, 08:14 AM
OU8AVW   [quote name='jim_hoyland' post='1987191' date='J...   Jan 23 2014, 08:49 AM
Steve Pratel   Got any tips on installing the pilot bearing? I t...   Jan 24 2014, 01:56 PM
Dave_Darling   No heat needed, it should just slip in. I think i...   Jan 23 2014, 09:50 AM
sean_v8_914   i see lots of cars missing the spacer that lives i...   Jan 23 2014, 12:13 PM
reharvey   i see lots of cars missing the spacer that lives ...   Jan 24 2014, 07:44 PM
jim_hoyland   Still need the M12 x 1.5 flywheel bolts, 25mm ? Au...   Jan 23 2014, 03:04 PM
bdstone914   Still need the M12 x 1.5 flywheel bolts, 25mm ? A...   Jan 24 2014, 12:53 PM
jim_hoyland   Still need the M12 x 1.5 flywheel bolts, 25mm ? ...   Jan 24 2014, 06:56 PM
Dave_Darling   The flywheel bolts are special parts, not standard...   Jan 24 2014, 01:54 PM
- Lo-Fi Version Time is now: 15th September 2026 - 01:31 PM
