driving/shifting question, to blip or not to blip, that is the Q |
opera guy |
Aug 2 2004, 04:41 PM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
say you're cruising down a long hill at 60mph. you put the car into neutral bc there are no other cars around, motor idling nicely (1200 or 900rpm) and you see that this descent is about to level off and want to put your car in 5th gear..... what do you do (Keeanu Reeve)?
1. no gas, stomp on clutch, throw into 5th and gas/de-clutch as normal 2. quick blip gas to 2k (let go), quick stomp on clutch, quick throw into 5th then gas/de-clutch 3. stomp on clutch, shift into 5th, blip to 2k (let go) then gas/de-clutch 4. others (please describe) c'mon.. help out an asian driver here (IMG:style_emoticons/default/mad.gif) <-- as close to beedy eye as the smilies can get (its ok, im chinese) |
SirAndy |
Aug 2 2004, 05:08 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
oh, and once you mastered the above, start doing THE OPPOSITE in tight corners where you have understeer.
if you come up a tight corner at fairly high speed and you can't get your frontend to turn in nicely, downshift right when you get into the corner without ANY gas and pop the clutch. that will swing your ass around, then apply *plenty* of gas to get the car out of the corner straight. NOTE: this only works in very slow corners, at higher speed, you'll upset your car and spin. oh, the joy of driving! (IMG:style_emoticons/default/driving.gif) Andy |
Lo-Fi Version | Time is now: 7th June 2024 - 03:58 PM |
