| jim_hoyland |
Jan 22 2014, 02:54 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,130 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
I previously acquired all the parts for a clutch replacement: flywheel, pressure plate, clutch, throw out bearing, and the clips, seals, bolts, washers, and bushing that go along with the main parts.
Two questions: 1. I have two clutch disks, a 6 spring and a 4 spring. Which would be preferred for street driving ? 2. I do not have a new flywheel pilot bearing; should I buy one before I start. And, would a VW parts house carry them. Car is going in next week to replace everything, just want to have all the parts on-hand |
| jim_hoyland |
Jan 23 2014, 03:04 PM
Still need the M12 x 1.5 flywheel bolts, 25mm ? Autoparts store ?
| bdstone914 |
Jan 24 2014, 12:53 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,379 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Still need the M12 x 1.5 flywheel bolts, 25mm ? Autoparts store ? Jim, In another thread The Cap'n replied that they can be reused. I have a used set you can have or they are available new. http://www.pelicanparts.com/cgi-bin/smart/...-014-336-1-M100 Bruce |
jim_hoyland Flywheel Pilot Bearing Jan 22 2014, 02:54 PM
SLITS Ok Jim,
The 4 spring was for the /4. Supposedly ... Jan 22 2014, 03:55 PM
gunny You need a new pilot bearing to go with your new f... Jan 22 2014, 04:55 PM
Jon H. I got a few engine parts from the local VW shop, t... Jan 22 2014, 04:59 PM
Mark Henry The pilot bearing is a pretty standard part, VW ty... Jan 22 2014, 05:15 PM
jim_hoyland Thank's for the tips. All the parts are new; ... Jan 22 2014, 07:05 PM
bdstone914
Thank's for the tips. All the parts are new; ... Jan 22 2014, 09:30 PM
Mark Henry
Thank's for the tips. All the parts are new;... Jan 22 2014, 10:16 PM
jim_hoyland
[quote name='jim_hoyland' post='1987191' date='Ja... Jan 23 2014, 08:14 AM
OU8AVW
[quote name='jim_hoyland' post='1987191' date='J... Jan 23 2014, 08:49 AM
Steve Pratel
Got any tips on installing the pilot bearing? I t... Jan 24 2014, 01:56 PM
Dave_Darling No heat needed, it should just slip in. I think i... Jan 23 2014, 09:50 AM
sean_v8_914 i see lots of cars missing the spacer that lives i... Jan 23 2014, 12:13 PM
reharvey
i see lots of cars missing the spacer that lives ... Jan 24 2014, 07:44 PM
jim_hoyland
Still need the M12 x 1.5 flywheel bolts, 25mm ? ... Jan 24 2014, 06:56 PM
Dave_Darling The flywheel bolts are special parts, not standard... Jan 24 2014, 01:54 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th September 2026 - 01:32 PM |
