Alfieg23 |
Newbie ![]() Group: Members Posts: 44 Joined: 7-January 14 From: Miramar, Florida Member No.: 16,854 Region Association: South East States ![]() |
I just purchased a 1972 with a replacement 1.8L engine with L-Jetronic Fuel Injection. I want to change the OEM distributor to electronic ignition but don't know which would be best. I've been reading a lot on this site as well as Google and have come up with three (Mallory Unilite, Petronix SVDA and Hot Spark SVDA. Is there a consensus as to which is best? Thanks in advance for your help.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
They may not ever burn out, but the notoriously weak rubbing block will fail and the points will close up, altering both the dwell and the timing. Besides points, my next favorite is a Compufire. A Pertronix drop in unit, despite it's abysmal failure rate, is FAR better than the Hot Spark setup. No way would I abandon the stock distributor, especially because the L-jet in your car requires a vacuum retard function to properly set the timing and to provide the correct idle speed and tip-in response.
The Cap'n |
Alfieg23 |
They may not ever burn out, but the notoriously weak rubbing block will fail and the points will close up, altering both the dwell and the timing. Besides points, my next favorite is a Compufire. A Pertronix drop in unit, despite it's abysmal failure rate, is FAR better than the Hot Spark setup. No way would I abandon the stock distributor, especially because the L-jet in your car requires a vacuum retard function to properly set the timing and to provide the correct idle speed and tip-in response. The Cap'n Thanks, Cap'n Krusty. What about spark plugs and wires? I was thinking of using Bosch plugs and the 8.5mm Magnecor wires. The car currently has the plug wires that connect to the plastic tube that fits onto the plugs and has the round rubber gasket to seal the opening in the engine tin. Thanks for your help. |
Lo-Fi Version | Time is now: 17th June 2024 - 01:38 PM |
