| wndsnd |
Feb 4 2014, 09:03 PM
You wanted a horse, but got a goat. Nobody wants a goat.... ![]() ![]() ![]() ![]() Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
Any ideas what might be up here? Obviously the cable is turning. Is there a little plastic gear inside the guage that connects the two that could be broken?
Thanks John |
| toolguy |
Feb 4 2014, 10:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
there is a plastic gear inside off the speedo that works the odometer. . my experience is it starts slipping on the shaft. . not a hard fix to do but you have to pull the case off the speedo assemble. . 2 screws in the rear after you pry off the bezel. . . .
or like you said ignore it or buy a different speedo [ and guess how long that one will last] as this is a common issue. . |
| r_towle |
Feb 4 2014, 10:11 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
there is a plastic gear inside off the speedo that works the odometer. . my experience is it starts slipping on the shaft. . not a hard fix to do but you have to pull the case off the speedo assemble. . 2 screws in the rear after you pry off the bezel. . . . or like you said ignore it or buy a different speedo [ and guess how long that one will last] as this is a common issue. . It's a pot metal gear.....so it can be crushed to fit. |
wndsnd Speedometer works odometer does not Feb 4 2014, 09:03 PM
r_towle Yup, it's a gear on a shaft that is no longer ... Feb 4 2014, 09:20 PM
bdstone914
Yup, it's a gear on a shaft that is no longer... Feb 6 2014, 09:50 PM
Kirmizi http://www.pelicanparts.com/techarticles/M...auge_... Feb 4 2014, 09:32 PM
wndsnd Thanks but that really looks like a pain in the as... Feb 4 2014, 09:45 PM
r_towle Nah, it's a quiet evening.
The hardest part is... Feb 4 2014, 10:08 PM
r_towle I did not take anything apart from what I recall..... Feb 4 2014, 10:11 PM
timothy_nd28 I repaired a few by injecting some locktite with a... Feb 4 2014, 10:20 PM
euro911 I repaired a few by injecting some locktite with a... Feb 4 2014, 11:04 PM
timothy_nd28
I repaired a few by injecting some locktite with ... Feb 4 2014, 11:11 PM
r_towle John, dude....seriously...
Send you gauges to Tim... Feb 4 2014, 10:26 PM
914itis I agree
Send it to Tim. The pelican article is n... Feb 4 2014, 10:34 PM
euro911 um, :busted!: ...
Hey, I did find the wiring ... Feb 5 2014, 04:01 AM
Mblizzard I have to say sending my gauges to Tim was the bes... Feb 5 2014, 08:29 AM
chads74 I know its a bit off topic, but what causes the sp... Feb 5 2014, 10:35 AM
Dave_Darling Often, it's a speedo cable that is starting to... Feb 5 2014, 05:19 PM
r_towle Look for this pot metal gear.
This is the one that... Feb 6 2014, 10:10 PM
Dave_Darling Here's another take on the odometer repair thi... Feb 6 2014, 10:38 PM
euro911 This is the gear
Feb 6 2014, 11:02 PM
Bob L.
This is the gear
That's the one that is ... Mar 23 2014, 06:30 PM
euro911 :thumbsup: Mar 23 2014, 07:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 05:26 AM |
