| worn |
Feb 4 2014, 10:58 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
When I was stripping the tub I wasn't as respectful to the vapor lines running under the rockers from engine to tank as I might have been. Also I am not sure where they all are (no smiley for what an idiot).
At any rate they seem to be a PVC material that is either supposed to be kind of stiff or has hardened with the age. They look black, and I suppose they may have started that way. Other than that they look like tygon tubing. I can find no replacement source. I probably won't have space for the catalytic converter in the 3.2, but I see no reason not to use this device for reducing emissions. But what should I use? Great thing is that this group will find me an answer (of some sort). Thanks so much! |
| 76-914 |
Feb 4 2014, 10:27 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
I think I posted this a while back. If you can't find it pm me, I'll find the link. I just moved my canister back to the engine and ran a 1/4" alum tube from the tank back to the canister. It mounts on the R side Top engine. Much easier than running 2-12mm hoses.
worn vapor lines Feb 4 2014, 10:58 AM
SLITS Thin wall, flexible plastic tubing. Only carries ... Feb 4 2014, 01:20 PM
flash914 I work on large trucks and I would look at air bra... Feb 4 2014, 01:24 PM
boxsterfan Some people just use rubber hose. You might be ab... Feb 4 2014, 02:12 PM
Philip W. sorry for the highjack but somewhat related, is th... Feb 4 2014, 02:20 PM
SLITS
sorry for the highjack but somewhat related, is t... Feb 4 2014, 02:44 PM
ruby914 Polyethylene Ice Maker supply line
http://www.low... Feb 4 2014, 11:03 PM
toolguy low pressure drip irrigation supply line Feb 5 2014, 01:25 AM
euro911 Like Ron, my hose dumps out below the firewall. If... Feb 5 2014, 04:07 AM
topatrout914
Like Ron, my hose dumps out below the firewall. I... Feb 5 2014, 07:00 AM
Philip W.
Like Ron, my hose dumps out below the firewall. ... Feb 5 2014, 07:15 AM
rhodyguy i found pellets for REAL cheap at amazon. plastic ... Feb 5 2014, 07:23 AM
MMW Why not use hard nylon fuel line? Easily availabl... Feb 5 2014, 07:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:04 PM |
