| worn |
Feb 4 2014, 10:58 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
When I was stripping the tub I wasn't as respectful to the vapor lines running under the rockers from engine to tank as I might have been. Also I am not sure where they all are (no smiley for what an idiot).
At any rate they seem to be a PVC material that is either supposed to be kind of stiff or has hardened with the age. They look black, and I suppose they may have started that way. Other than that they look like tygon tubing. I can find no replacement source. I probably won't have space for the catalytic converter in the 3.2, but I see no reason not to use this device for reducing emissions. But what should I use? Great thing is that this group will find me an answer (of some sort). Thanks so much! |
| rhodyguy |
Feb 5 2014, 07:23 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
i found pellets for REAL cheap at amazon. plastic canisters can be opened, not so sure about the metal ones. i recently hooked up the evap system in a 74' with carbs. stock location was the rear of the engine bay. one line from the single fitting on the fan shroud and the small line that runs thru the center tunnel to the canister. no lines in the dr side long.
worn vapor lines Feb 4 2014, 10:58 AM
SLITS Thin wall, flexible plastic tubing. Only carries ... Feb 4 2014, 01:20 PM
flash914 I work on large trucks and I would look at air bra... Feb 4 2014, 01:24 PM
boxsterfan Some people just use rubber hose. You might be ab... Feb 4 2014, 02:12 PM
Philip W. sorry for the highjack but somewhat related, is th... Feb 4 2014, 02:20 PM
SLITS
sorry for the highjack but somewhat related, is t... Feb 4 2014, 02:44 PM
76-914 I think I posted this a while back. If you can... Feb 4 2014, 10:27 PM
ruby914 Polyethylene Ice Maker supply line
http://www.low... Feb 4 2014, 11:03 PM
toolguy low pressure drip irrigation supply line Feb 5 2014, 01:25 AM
euro911 Like Ron, my hose dumps out below the firewall. If... Feb 5 2014, 04:07 AM
topatrout914
Like Ron, my hose dumps out below the firewall. I... Feb 5 2014, 07:00 AM
Philip W.
Like Ron, my hose dumps out below the firewall. ... Feb 5 2014, 07:15 AM
MMW Why not use hard nylon fuel line? Easily availabl... Feb 5 2014, 07:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:12 PM |
