How much needs to be cut off the lover valve covers, /6 is going to get DONE |
PanelBilly |
Feb 4 2014, 09:58 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Distributor went to Jerry Woods today. Yesterday I ordered the flywheel. Cams left for Webcams on Friday. I need to keep the ball rolling so everything is ready when the machine work is done in March. Checking the brain-trust for the modification that needs to be made to the covers
PanelBilly |
Feb 5 2014, 01:00 PM
I was searching bird last night and didn't see it.
mskala |
Feb 5 2014, 01:04 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I probably have my own pictures at home, but it is really not something easily
seen. For me it was necessary to go back and forth; grind a bit, check, grind a bit ... Also, if you are simply in a hurry to get going, there's nothing stopping you from using the 930 covers intact, it's just that to remove them you will need to lower the engine. So you could just put off the whole thing until the next valve adjust/oil change. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:18 AM |
