Sheridan Rear Spoiler, Now with How-To instructions! |
tomeric914 |
Feb 5 2014, 07:20 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Direct link to the "How-To" part: http://www.914world.com/bbs2/index.php?s=&...t&p=2022462
I received my Sheridan Rear Spoiler today and WOW is it ever nice! It is a simple piece but by far the nicest piece of fiberglass I have ever purchased. To do it justice, what is the best way to mount it to the deck? Sure, I could run stainless TEK screws through it but what have others done? If you have pictures, please post! thanks |
tomeric914 |
Feb 6 2014, 08:13 AM
Doesn't it have bolt protruding from the bottom? If not I'd use riv nuts. I can post a picture of mine if you like. Yes, please post a pic of yours. There are no bolts protruding. O-ring, closed end rivnuts may be the best way to go to prevent any leaks into the trunk area. I'd want to back up each riv nut with a fender washer if possible. ...or possibly those screws that tighten from both ends (forgot what they're called.) Those are typically called binding rivets. Years ago they were used to bind pages of a book together. I used Stainless Nuts & Bolts I saw that. The screw pattern looks somewhat random. Was there a reason for that? |
Randal |
Feb 6 2014, 02:24 PM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
[quote name='tomeric914' date='Feb 6 2014, 06:13 AM' post='1994236']
[quote name='Randal' post='1994087' date='Feb 5 2014, 11:20 PM'] Doesn't it have bolt protruding from the bottom? If not I'd use riv nuts. I can post a picture of mine if you like. [/quote] Yes, please post a pic of yours. There are no bolts protruding. O-ring, closed end rivnuts may be the best way to go to prevent any leaks into the trunk area. I'd want to back up each riv nut with a fender washer if possible. Couldn't find the picture I wanted to show you, but again Riv nuts work great. My mechanic made a small iron bar, with a hole in one end to use tightening up Riv nuts with a socket. Works good, especially with the larger riv nuts you will want to use. Please post a picture of the spoiler and also where it will be going so we can see both parts. |
Lo-Fi Version | Time is now: 9th June 2024 - 12:14 PM |
