| Dredwin |
Feb 10 2014, 09:27 PM
Member ![]() ![]() Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains
I haven't seen this car in person but the body has some rust. The "hell hole" has been repaired. But I haven't done body work before. I'm a decent mechanic but have never done body work. (although I have drywalled the basement).
Looking over the forum, I know there are other areas to look for rust, but how difficult is this to repair? Thanks for any help you can give Attached image(s)
| Chris H. |
Feb 11 2014, 07:24 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,079 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Yep this is the clincher right here...
It's not really "natural" for rust to form there. It came from the inside out. See how its lumpy under the vinyl? That's more rust bubbles. Some people can fix that easily but it can be very frustrating for a first-time build. You can expect it to be much worse under there. |
| ClayPerrine |
Feb 11 2014, 10:24 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Yep this is the clincher right here... It's not really "natural" for rust to form there. It came from the inside out. See how its lumpy under the vinyl? That's more rust bubbles. Some people can fix that easily but it can be very frustrating for a first-time build. You can expect it to be much worse under there. Actually it is very common for a 914 to rust there. Porsche/VW put foam in the corners to prevent rust. Well, it did just the opposite. The foam sucked up water, and held it against the mild steel sheet metal, and rust resulted. Use carburetor cleaner to remove the foam. Cut out the rusted area, and weld in a new section. The most common places that cause a 914 to be terminal is under the battery tray, the hell hole and the suspension console. |
Dredwin Rust damage hard to fix? Feb 10 2014, 09:27 PM
partwerks I have a small rust spot on the passenger side als... Feb 10 2014, 09:36 PM
Ferg Based just on those two pics, if u can't weld ... Feb 10 2014, 09:57 PM
Mike Bellis I've seen better cars that were free... :( Feb 10 2014, 10:18 PM
KELTY360 It's an iceberg. Feb 10 2014, 11:36 PM
Dredwin
It's an iceberg.
Or is this the Titanic? I... Feb 11 2014, 12:23 AM
KELTY360
It's an iceberg.
Or is this the Titanic? ... Feb 11 2014, 07:29 AM
worn
[quote name='Dredwin' post='1996322' date='Feb 10... Feb 11 2014, 09:49 AM
worn
No, you'd be the Titanic if you hit on this ... Feb 11 2014, 11:21 AM
ConeDodger Keep looking... :( Feb 11 2014, 12:21 AM
somd914 Looks like you have rust at the lower end of the d... Feb 11 2014, 04:56 AM
CptTripps Yeah...let someone else "save" that one. Feb 11 2014, 05:01 AM
76-914 This would be a much better start with a little ru... Feb 11 2014, 09:58 AM
Chris H. Oh I'm aware it's common for a 914 to rust... Feb 11 2014, 10:40 AM
rdauenhauer BTW that's not so much "foam" like t... Feb 11 2014, 11:04 AM
Dredwin Thanks for the advice. The guy says is some rust ... Feb 11 2014, 11:29 AM
KELTY360
Thanks for the advice. The guy says is some rust... Feb 11 2014, 03:46 PM
ClayPerrine One suggestion... show up with an ice pick and pok... Feb 11 2014, 01:09 PM
rdauenhauer :agree:
Best option would be to remove the rocker... Feb 11 2014, 01:33 PM
Dredwin
Thanks for the advice. The guy says is some rus... Feb 12 2014, 02:28 AM
CptTripps :agree: with your decision to "move on"
... Feb 12 2014, 06:00 AM
KELTY360
My (unsolicited) advice: Go out there with enoug... Feb 12 2014, 07:31 AM
Dredwin
My (unsolicited) advice: Go out there with enou... Feb 12 2014, 08:04 PM
CptTripps Here's the car.
http://seattle.craigslist.org... Feb 12 2014, 08:31 PM
Mikey914 I'm sure the guy has the $2500 into it, t... Feb 13 2014, 11:20 AM
audio_file
Here's the car.
http://seattle.craigslist.or... Feb 13 2014, 12:07 PM
Mike Bellis That car is about $10,000 in metal work to re... Feb 13 2014, 08:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:10 PM |
