| Dredwin |
Feb 10 2014, 09:27 PM
Member ![]() ![]() Group: Members Posts: 71 Joined: 21-December 13 From: Colorado Springs Member No.: 16,783 Region Association: Rocky Mountains
I haven't seen this car in person but the body has some rust. The "hell hole" has been repaired. But I haven't done body work before. I'm a decent mechanic but have never done body work. (although I have drywalled the basement).
Looking over the forum, I know there are other areas to look for rust, but how difficult is this to repair? Thanks for any help you can give Attached image(s)
| Chris H. |
Feb 11 2014, 10:40 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,079 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Oh I'm aware it's common for a 914 to rust there. Seen it dozens of times here in the midwest since the salted roads in the winter accelerated the problem. That's the first spot I check when looking at a car in Chicago since flippers had a tendency to slap a chunk of bondo in there.
My point was that if you look at the rust not knowing much about 914's it's not a very natural spot for rust to accumulate since it's sloped in a way that would not trap water. It's rusty because it's rusting from the inside out. |
Dredwin Rust damage hard to fix? Feb 10 2014, 09:27 PM
partwerks I have a small rust spot on the passenger side als... Feb 10 2014, 09:36 PM
Ferg Based just on those two pics, if u can't weld ... Feb 10 2014, 09:57 PM
Mike Bellis I've seen better cars that were free... :( Feb 10 2014, 10:18 PM
KELTY360 It's an iceberg. Feb 10 2014, 11:36 PM
Dredwin
It's an iceberg.
Or is this the Titanic? I... Feb 11 2014, 12:23 AM
KELTY360
It's an iceberg.
Or is this the Titanic? ... Feb 11 2014, 07:29 AM
worn
[quote name='Dredwin' post='1996322' date='Feb 10... Feb 11 2014, 09:49 AM
worn
No, you'd be the Titanic if you hit on this ... Feb 11 2014, 11:21 AM
ConeDodger Keep looking... :( Feb 11 2014, 12:21 AM
somd914 Looks like you have rust at the lower end of the d... Feb 11 2014, 04:56 AM
CptTripps Yeah...let someone else "save" that one. Feb 11 2014, 05:01 AM
Chris H. Yep this is the clincher right here...
It... Feb 11 2014, 07:24 AM
ClayPerrine
It... Feb 11 2014, 10:24 AM
76-914 This would be a much better start with a little ru... Feb 11 2014, 09:58 AM
rdauenhauer BTW that's not so much "foam" like t... Feb 11 2014, 11:04 AM
Dredwin Thanks for the advice. The guy says is some rust ... Feb 11 2014, 11:29 AM
KELTY360
Thanks for the advice. The guy says is some rust... Feb 11 2014, 03:46 PM
ClayPerrine One suggestion... show up with an ice pick and pok... Feb 11 2014, 01:09 PM
rdauenhauer :agree:
Best option would be to remove the rocker... Feb 11 2014, 01:33 PM
Dredwin
Thanks for the advice. The guy says is some rus... Feb 12 2014, 02:28 AM
CptTripps :agree: with your decision to "move on"
... Feb 12 2014, 06:00 AM
KELTY360
My (unsolicited) advice: Go out there with enoug... Feb 12 2014, 07:31 AM
Dredwin
My (unsolicited) advice: Go out there with enou... Feb 12 2014, 08:04 PM
CptTripps Here's the car.
http://seattle.craigslist.org... Feb 12 2014, 08:31 PM
Mikey914 I'm sure the guy has the $2500 into it, t... Feb 13 2014, 11:20 AM
audio_file
Here's the car.
http://seattle.craigslist.or... Feb 13 2014, 12:07 PM
Mike Bellis That car is about $10,000 in metal work to re... Feb 13 2014, 08:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:43 PM |
