| bajafreaks |
Feb 12 2014, 09:35 PM
Member ![]() ![]() Group: Members Posts: 187 Joined: 7-February 14 From: Gardnerville, Nevada Member No.: 16,969 Region Association: Northern California |
The 74 I just bought doesn't have the original engine, how do I know if this car came with a 1.8 or 2.0 ??? vin#4742906720
| jcd914 |
Feb 12 2014, 10:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Porsche did not make a list public that has a connection between engine and VIN. And the emission information label in 74 was on the engine fan housing. I have heard you can call Porsche and they can look up info but you may have had to order a COA first, I don't know.
You say it has a non original engine, how do you know? What is in it now, engine, FI, Carbs? This is a long shot but depending in what has been done in the engine compartment you may find a clue. The 1.8 engine came with L-jet FI and they had a bracket for the Air Filter/Air Flow Meter that attached to the driver side inner long, the bracket would likely have left marks on the long if it had been there. Of course if the engine compartment has been repainted or something, probably not. Are you wanting to restore to original? Any year/size 914-4 engine can be put in any year 914-4, they are essentially plug & play. Good luck Jim |
| bajafreaks |
Feb 12 2014, 10:19 PM
Porsche did not make a list public that has a connection between engine and VIN. And the emission information label in 74 was on the engine fan housing. I have heard you can call Porsche and they can look up info but you may have had to order a COA first, I don't know. You say it has a non original engine, how do you know? What is in it now, engine, FI, Carbs? This is a long shot but depending in what has been done in the engine compartment you may find a clue. The 1.8 engine came with L-jet FI and they had a bracket for the Air Filter/Air Flow Meter that attached to the driver side inner long, the bracket would likely have left marks on the long if it had been there. Of course if the engine compartment has been repainted or something, probably not. Are you wanting to restore to original? Any year/size 914-4 engine can be put in any year 914-4, they are essentially plug & play. Good luck Jim I was told by the seller that it had a bus engine in it so I looked up the engine id and its for 80-83 vanagon. It has carbs now. I'll really just curious which engine the car came with and yes I do realize their interchangeable. |
bajafreaks 1974 1.8 or 2.0 Feb 12 2014, 09:35 PM
billh1963
The 74 I just bought doesn't have the origina... Feb 12 2014, 09:53 PM
bigkensteele Is it close to factory correct show level, or do y... Feb 12 2014, 09:59 PM
Cap'n Krusty The engine you think you have is substantially dif... Feb 12 2014, 10:36 PM
bajafreaks
The engine you think you have is substantially di... Feb 12 2014, 11:08 PM
John Jentz
[quote name='Cap'n Krusty' post='1997302' dat... Feb 13 2014, 09:34 AM
Cap'n Krusty
[quote name='Cap'n Krusty' post='1997302' da... Feb 13 2014, 12:44 PM
bajafreaks
[quote name='John Jentz' post='1997467' date='Feb... Feb 13 2014, 12:56 PM
bajafreaks See the red rectangle on the drivers sidewall? Is ... Feb 13 2014, 03:26 PM
dlkawashima
It reads engine size 120 CID
In that case, you... Feb 13 2014, 06:49 PM
bajafreaks
[quote name='bajafreaks' post='1997610' date='Feb... Feb 13 2014, 07:53 PM
Spoke Didn't they put a 1.8 or 2.0 emblem on the rea... Feb 13 2014, 10:09 AM
bajafreaks
Didn't they put a 1.8 or 2.0 emblem on the re... Feb 13 2014, 10:57 AM
dlkawashima Do you know if your car has its original gas tank?... Feb 13 2014, 12:18 PM
bajafreaks
Do you know if your car has its original gas tank... Feb 13 2014, 12:53 PM
Dave_Darling I believe that the 1.8s also came with that size. ... Feb 13 2014, 12:58 PM
Jeff Bowlsby 120 CID = 2-oh! Feb 13 2014, 06:33 PM
914_7T3 Great info on the expansion tank decals here. I a... Aug 13 2019, 12:28 PM
Superhawk996
Great info on the expansion tank decals here. I ... Aug 13 2019, 12:35 PM
bbrock
Great info on the expansion tank decals here. I ... Aug 13 2019, 09:13 PM
914_7T3
[quote name='914_7T3' post='2738033' date='Aug 13... Aug 13 2019, 11:38 PM
914Sixer I thin AA has reproduced your labels already. Aug 13 2019, 12:33 PM
914_7T3
... Aug 13 2019, 08:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th November 2026 - 04:56 PM |
