914 Improvements/mods?, Improvements you've done/ plan on doing |
ehokana |
Feb 13 2014, 09:50 PM
Member Group: Members Posts: 99 Joined: 11-August 13 From: SoCal Member No.: 16,237 Region Association: None |
I'm still slowly preparing to start my full '73 2.0 restoration- in the mean time, I've been driving the car and figuring out what needs to be done. I want to keep the car very close to stock, but also want to make a few improvements to make the car a little more enjoyable.
I'm thinking about doing a hydraulic cam on the rebuild and a little higher compression pistons, larger brake master, hydraulic lifts for the hood and trunk instead of the springs, and maybe ditching the inner door handles for pulls instead. (I guess I like the RS style look) I know there are a ton of mods out there and was wondering if anyone has experience with any that I'm thinking about doing, or have done any others that you would recommend. |
saigon71 |
Feb 14 2014, 07:31 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
+1 on the hi-torque mini starter. It's also lighter!
Along with other problems mentioned, I thought I remember reading that you actually lose HP with a hydraulic cam on a Type IV. I know a lot of folks run the larger 19mm master cylinder...but I'm not convinced it's really an upgrade to a stock braking system. I stuck with the 17mm M/C. Saw you were in California. Fuel pump vapor lock could be a problem for you if it's in the engine bay. I would recommend moving it up front under the gas tank as Porsche did on the 75-76 models. It happened to me once and put me in a bad spot...not fun. If the car doesn't have Billstein shocks all around, I think this would be a nice upgrade. My current project is getting better tunes in the teener. (IMG:style_emoticons/default/welcome.png) and good luck with your restoration! |
Lo-Fi Version | Time is now: 10th June 2024 - 04:01 PM |
