throttle cable install question |
rosenfe |
Feb 13 2014, 03:59 PM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
when replacing throttle cable,do you pull it out from passenger compartment or engine side.what about install do you insert from cabin to engine.searched for write up here.
toolguy |
Feb 13 2014, 08:18 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
before you pull the cable out of the tunnel, tie on a string, pull it out at the firewall with the string attached . . . use the string to pull the new cable back in with. . Point being, it's easy to get it wrapped around the clutch cable if you just shove it back in. . . If it gets wrapped around the clutch cable, the throttle will pull each time you step on the clutch. .
Cap'n Krusty |
Feb 14 2014, 10:43 AM
before you pull the cable out of the tunnel, tie on a string, pull it out at the firewall with the string attached . . . use the string to pull the new cable back in with. . Point being, it's easy to get it wrapped around the clutch cable if you just shove it back in. . . If it gets wrapped around the clutch cable, the throttle will pull each time you step on the clutch. . Will this stupid "tip" NEVER die? There's NO room for a knot to pass through the tube. Don't believe it? Listen to us laugh when you jam it all up and ask for help. The Cap'n |
Lo-Fi Version | Time is now: 10th June 2024 - 07:18 AM |
