| jpnovak |
Feb 14 2014, 10:05 PM
They call me "Nanoman" ![]() ![]() Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
Its time to sell my Dirty Penny. Penny was built on a 1975 Porsche 914 chassis. The chassis was found under a local oak tree as a roller. The car was built with a complete Subaru drivetrain for the GRM $2011 Challenge. The car spun a few bearings and has since received a new engine.
You can read all about the build here. http://www.914world.com/bbs2/index.php?sho...e++dirty++penny. Penny is currently configured with the following. DRIVETRAIN: ej20R twin turbo engine. Megasquirt ECU in factory case with factory wiring. Currently tuned at 18psi. Boost comes on late due to the TT setup. These are not currently setup sequential - but in parallel. Subaru transmission with hydraulic clutch Nissan Versa shift console for incredible ergonomics driving cable shift. SUSPENSION: 180# rear springs on Koni shocks 22mm Front torsions on 911 Carrera Boge dampers. front bushings were replaced with polygraphite (turned in a lathe - no squeaks) Kuhmo V700 tires 205-50-15 on 15x6 Rivearas. They could probably be balanced. MISC STUFF: Chassis rust was fixed by butt welded sheet metal. Chassis has Engman Kit installed. Interior painted with gray anti-skid paint and partial covered with gray Perlon. Driver's seat is carbon fiber GT3 replica Passenger seat is stock. No radio. Factory tach driven by MS ECU. Speedometer is actually a bicycle speedometer. Have a spare EJ20G engine, spare case, crank and rods. Transmission just started making a noise. Probably the infamous 5th gear input shaft bearing. New flywheel nose and release bearings. The car is fast at high rpm but will drive very docile around town. It can spin cold tires in third under boost. Asking $4500. (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-10736-1317499190.1.jpg) I will get some new pictures up tomorrow. I am going to kick myself for posting this but after a few margaritas and a potential move its just gotta happen. |
| matthepcat |
Feb 16 2014, 11:27 AM
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Cool engine. Designed to handle higher RPM than your standard EJ20. Potential buyer can change to a single turbo configuration easily and take advantage of modern turbo technology.
Hope it finds a good home! |
jpnovak FS. 1975 Subaru Conversion Feb 14 2014, 10:05 PM
x-faktory I remember following the build of this 914. Good l... Feb 15 2014, 11:54 AM
jpnovak Thanks Al.
I do have a second engine (spun beari... Feb 16 2014, 09:23 PM
jpnovak Here are some pictures from this afternoon. I was... Feb 23 2014, 09:12 PM
Andyrew If this was in california...... Mar 1 2014, 03:12 AM
jpnovak Its only a truck ride away.
I can probably help... Mar 7 2014, 03:04 PM
badmiata I think If I had the money :( Its close to what I ... Mar 11 2014, 04:51 PM
jpnovak any offers? Mar 23 2014, 11:09 PM
rnellums On jalopnik today! GLWTS!
http://jalopnik... Mar 25 2014, 07:51 AM
914rrr PM sent Mar 27 2014, 08:28 AM
jpnovak Sale Pending receipt of funds. Apr 2 2014, 01:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th March 2026 - 02:59 AM |
