Sloppy gear shift, really sloppy gear shift |
cal914 |
Feb 16 2014, 02:03 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
When my 1970 rear shift 914 is in neutral the gear shift is so floppy you struggle to find a gear,also when cold it goes into second[once you find it ] nicely after a little while you struggle big time to get into gear
thanks |
GeorgeRud |
Feb 16 2014, 02:53 PM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
First step is to replace all the nylon bushings and cups between the shift knob and the transmission. The early 4 cylinder tail shift transmission has the most connection points, so the gearshift does require quite a lot of monkey motion to actually shift the gears in the transmission.
There are plenty of options, all are much more expensive than replacing the bushings and adjusting the linkage. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:00 PM |
