Crank/cam alignment |
Shindog1961 |
Feb 16 2014, 11:51 PM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
So putting an engine back together all the books say aligning the cam and crank gears just line up the 2 dots on the crank and put the 1 dot on the cam between them. Is mine the only crank gear with no markings? The 1 dot is there on the cam gear, but nothing on the crank. How can you align the gears? Can it be done accurately? Any help would be great.
stugray |
Feb 17 2014, 10:39 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The dot on the crank gear is indexed from the keyway.
I have pics at home. If you can get a pic of a gear with the dot that shows the keyway, you can just count teeth. But my first thought was also that you might have the gear on backwards. |
bdstone914 |
Feb 17 2014, 11:06 AM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The dot on the crank gear is indexed from the keyway. I have pics at home. If you can get a pic of a gear with the dot that shows the keyway, you can just count teeth. But my first thought was also that you might have the gear on backwards. Unless you are running straight cut gears the teeth would not align if the crank gear were on backwards. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:43 AM |
