| Alapone |
Feb 18 2014, 12:45 PM
Member ![]() ![]() Group: Members Posts: 110 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
Hello all,
I am relatively new to the world of the 914. I have been wanting to convert my (mostly stock) 1975 914 2.0l from FI to carbs since I bought it about a year and a half ago. I recently purchased, via an obscure but cheap ebay add, a pair of what turned out to be Weber DCNF 40mm carburetors and manifolds. I was under the impression they were IDFs (rookie move I know)... I have done a little research on these carbs for type IV application and have read widely varied opinions on the matter ranging from "throw them away immediately" to "could be a nice setup". I have a set of manifolds that look as if they will match with the engine and if they do I will likely give these DCNFs a shot. I am told these DCNFs were primarily used on alfa, ferrari, fiat and vw type I and III engines for a variety of reasons and are not the ideal carb for the type IV. Having these DCNFs in hand though makes me think twice about starting from scratch looking for some IDF 40s or 44s. My main question is, can I run these DCNFs with my 2.0l without problem in proper tune? If these are an ok carb for the type IV engine does anyone know where I can get a set of manifolds? Please excuse the rambling and/or inconsistent information gathered by a 914 newb. Any help with this matter would be much appreciated. -Andrew |
| Mark Henry |
Feb 18 2014, 01:14 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I'm probably the closest thing to a DCNF Guru here and I say no, they are a bad choice for a 914.
The DCNF works well in a type one beetle/bus application for a cruiser type car. In fact for a performance daily driver, that you need to get decent fuel economy, perfect AFR and engine longevity out of it is one of the best carbs. But once you add high side G-loads to the DCNF the carb starts to have fuel/float issues. A hard left in a 914 will result in the carb's completely shutting off. Please keep in mind the a DCNF is a Lambo/Ferrari carb that is mounted 90* of the VW mounting, thus they are not affected (the same way) by these G-loads. Also they are great in the type 1 as the barrel are a perfect match for the close together intake ports of a type one head, but this is not so great for the type 4, even in a bus. So I'd say they work great in a type one, sketchy in a type 4 engine bus, but they really suck in a 914. BTW the 1967 bus in my signature has real Gene Berg DCNF "42 specials" on it, That engine I built form a GB kit in 1991. |
| Alapone |
Feb 18 2014, 01:47 PM
I'm probably the closest thing to a DCNF Guru here and I say no, they are a bad choice for a 914. The DCNF works well in a type one beetle/bus application for a cruiser type car. In fact for a performance daily driver, that you need to get decent fuel economy, perfect AFR and engine longevity out of it is one of the best carbs. But once you add high side G-loads to the DCNF the carb starts to have fuel/float issues. A hard left in a 914 will result in the carb's completely shutting off. Please keep in mind the a DCNF is a Lambo/Ferrari carb that is mounted 90* of the VW mounting, thus they are not affected (the same way) by these G-loads. Also they are great in the type 1 as the barrel are a perfect match for the close together intake ports of a type one head, but this is not so great for the type 4, even in a bus. So I'd say they work great in a type one, sketchy in a type 4 engine bus, but they really suck in a 914. BTW the 1967 bus in my signature has real Gene Berg DCNF "42 specials" on it, That engine I built form a GB kit in 1991. Thanks for all the help here. So assuming that the IDFs are the way to go, am I still going to need to swap out for a hotter cam for the carbs to run well? I currently have no autox or track day ambitions or want for substantial performance improvement. Is the cam 100% necessary to go with the carbs? |
Alapone Weber DCNF vs IDF Feb 18 2014, 12:45 PM
Elliot Cannon I have weber 44idf's on my car and once I got ... Feb 18 2014, 12:58 PM
DBCooper Yes, you can. The DCNF's are an older design ... Feb 18 2014, 01:01 PM
SLITS You read, I'm tired Feb 18 2014, 01:04 PM
ThePaintedMan
Thanks for all the help here. So assuming that th... Feb 18 2014, 01:59 PM
Alapone
Thanks for all the help here. So assuming that t... Feb 18 2014, 02:04 PM
ThePaintedMan
Yes the car is currently running FI not sure whic... Feb 18 2014, 02:12 PM
DBCooper
But once you add high side G-loads to the DCNF th... Feb 18 2014, 03:45 PM
Mark Henry
But once you add high side G-loads to the DCNF t... Feb 18 2014, 04:05 PM
saigon71 :agree:
I was in a similar situation a few years... Feb 18 2014, 03:01 PM
Alapone
:agree:
I was in a similar situation a few year... Feb 18 2014, 03:30 PM
sean_v8_914 gene berg specials had extra progression holes dri... Feb 18 2014, 04:51 PM
Mark Henry
gene berg specials had extra progression holes dr... Feb 18 2014, 05:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:05 PM |
