Crank/cam alignment |
Shindog1961 |
Feb 16 2014, 11:51 PM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
So putting an engine back together all the books say aligning the cam and crank gears just line up the 2 dots on the crank and put the 1 dot on the cam between them. Is mine the only crank gear with no markings? The 1 dot is there on the cam gear, but nothing on the crank. How can you align the gears? Can it be done accurately? Any help would be great.
Dave_Darling |
Feb 17 2014, 11:56 PM
If there are no dots, could the gear be the wrong gear? Maybe one from some other application that (mostly) fits? Does it have the right number of teeth?
--DD |
AE354803 |
Feb 18 2014, 07:34 PM
Member Group: Members Posts: 232 Joined: 13-August 12 From: Southern California Member No.: 14,801 Region Association: Southern California |
If there are no dots, could the gear be the wrong gear? Maybe one from some other application that (mostly) fits? Does it have the right number of teeth? --DD I had a bad gear on my crankshaft (and a bad crankshaft). I would make sure that it has the right amount of teeth, but for your trouble it might be safer to just replace it. You can do it pretty easily with a 3 jaw puller and a plumbers torch Part# 021 105 209 A (I got mine from Parts Heaven). http://www.914world.com/bbs2/index.php?s=&...t&p=1849695 |
Lo-Fi Version | Time is now: 6th June 2024 - 02:38 PM |
