Eliminating Heat Exchangers |
Bulldog9 |
Feb 18 2014, 08:41 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
The rust monster destroyed my heat exchangers, and for this initial build I will be going without them. I'm exploring some alternative heat options (in #770 update) and have made some headway, but for now I will be going without exchangers, and need to figure out what to do with the normal outlets in the shroud that connect to the exchangers and then cabin.
What is the best way to deal with the air outlets in the fan shroud? I could Fill with JB weld, but not a good idea if I ever decide to or if I stumble on a set of exchangers (unlikely) but dont want to just leave open......... found these, too bad they will not work http://www.ebay.com/itm/like/130830510710?lpid=82 |
jcd914 |
Feb 18 2014, 11:34 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If I remember correctly (always a big if) I have read where testing showed blocking the outlets off disrupted the air flow in the blower housing and caused a net lose in cooling.
That said, I have a 2.0L engine with headers and the outlets are blocked with small aluminum plates. Jim |
Lo-Fi Version | Time is now: 8th June 2024 - 10:19 PM |
