Bulldog9 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region ![]() |
Got my crank/flywheel/fan stuff back and it looks like they lost the bolt that mounts the fan/fan mount to the crank. I know it is an M8X30, and assume It needs to be a hardened bolt, just wondering where you guys get this misc hardware.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
The bolt you need has a flange with a serrated surface. You also need a large, thick, flat washer that will cover the end of the hub. The bolt isn't hardened, IIRC, as it doesn't actually hold anything once the hub is firmly in place on the taper and woodruff key.
The Cap'n |
Lo-Fi Version | Time is now: 1st July 2025 - 06:58 AM |
