Corner Balance, Idiot check of percentages... |
yeahmag |
Feb 18 2014, 04:44 PM
Advanced Member Group: Members Posts: 2,423 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
I'm getting very close to aligning and corner weighting the car. What sort of percentages should i be looking for in cross and front to rear? I would guess 50% cross with me in it and closer to 45% front/55% rear.
brant |
Mar 1 2014, 06:20 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I can still feel my TB Diff...
If I go into a high speed sweeper and the car doesn't feel like its going to make it... I can mash the throttle and feel the line change and make the corner. If I white knuckle and don't mash the throttle I usually drive off track but the TB diff will slightly turn the car if you trust it and floor it right at the moment you don't think you will make the corner... my old locked diff did the same thing but 4times more. the only way around the corner with a locked diff was to - kick the rear end out and then rotate the car.. - mash the throttle when the front end was pointing the direction you wanted to go in the rotation sequence. - and go straight in the direction it was pointing the big advantage to the locked diff was: 1) over cooking the braking zones in every single corner and making it due to the fact you were sliding sideways through the braking zone and cutting speed due to the slide. 2) being slightly faster due to the constant slide and practicing this style of loosing the car-catching the car... loosing the car-catching the car, in every single corner. The style taught you better reaction and better skilll at catching it. but it also made it a lot easier to mess up since you had to catch it 10-15 times per a lap. The big advantage to the TB diff is - the abilility to drive off line in the marbles or on wet or imperfect surfaces. - the TB diff is a lot smoother. Just as good at full throttle-out and only gives up anything under braking. But MUCH better tire life and MUCH easier to drive due to the technique differences. - more forgiving of driver error, easier on the equiptment, and easier to maintain concentration... - easier to be in traffic, since loosing controll side by side at 80mph is such a fine line when your 2 foot away from the other guys door. if there was a driver error with the locked diff it was less forgiving you would loose 5 car lengths to the next guy if he shut the door or you misjudged anything. I think it was faster on open laps, but you could never let up and never loose your momentum. |
Randal |
Mar 2 2014, 11:39 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
[quote] [quote name='brant' date='Mar 1 2014, 04:20 PM' post='2004815']
I can still feel my TB Diff... If I go into a high speed sweeper and the car doesn't feel like its going to make it... I can mash the throttle and feel the line change and make the corner. If I white knuckle and don't mash the throttle I usually drive off track but the TB diff will slightly turn the car if you trust it and floor it right at the moment you don't think you will make the corner...[/quote] Interesting comments: I've never had my car on the track, just autox and hillclimbs. A hillclimb isn't where you want to experiment, so big sweepers there are very measured, from a drivers point of view. Although a great (tight) sweeper is the first turn at Medford (Fall Enduro Course). http://www.ssccmedford.org/track.html It's right after the straight, so very fast and scary. Should have tried your thinking there, but didn't know and now it's too late. High speed sweepers in autoxing are unfortunately rare. But when they are there I go through them flat out, so guessing the TB diff is allowing that to happen. |
Lo-Fi Version | Time is now: 11th June 2024 - 03:31 AM |
