Converting to a 914-6, Back yard Bob's (Dan's) way |
Root_Werks |
Aug 5 2004, 12:24 PM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Okay, so this is about the 5th 914-6 conversion I have done. They are all drivers to this day. Heck, Even Craigh Laughlin has one of my old ones! My goal is to put as many 914-6's out on the road as possible since I think that is what the desing intended for them to be anyway. Anyway, I have heard soem thoughts about costs or how hard it is to convert. Nah, just time really. yeah, a few parts, but mostly just some time. Lets visit the part$ shall we. You will probalby need the following (as in not worth making):
Tank - Lots-o-options, but don't spend over $500 on one Headers - $450 - 500 Mount - Zowie! Lots-o-options here as well. I have a jig to make my own, it works, but takes time. It is not hard, but takes a lot of time. I gave up and grabbed a patrick moly mount just today. I am running out of time. Everyting else, you can make or do yourself. I will show you how in this thread over the next couple of weeks since that is all the time I have left! Here is a shot of the holes drilled for the oil tank. Yep, I am using a Vellios tank yet again. They work great and use the later filters. Also, you can go down to your local industrial supply shop and have them make the pressure hose for like $40. The suction hose is even easier, but more on that later. |
Root_Werks |
Aug 6 2004, 08:32 AM
So there you have the tin! 22 gauge can be cut with a really good snippers, or you can use a little jig saw, either way I clean it up with a little grinder. You know what? After you install these, they look great! It is not show quality, but they do the job and even look good. Over the years I have made some sets for people, but they understand it is not a professional job. To bend 90degree corners on a radias, I simply slit, slit, slit, slit, bend, bend, bend..... I have gone back over and welded, grinded those smooth before, but it is a waist as you don't see them once installed. You only see the flat finished parts. People who have seen my tin can't tell. (IMG:style_emoticons/default/smile.gif)
Okay, lets look at the tank I am using. It is a Vellios tank, like the 3rd one I have used. I like them, good price, in a lot of conversions so you know they work now. Some of his earlier stuff didn't have baffles in the tank which caused the oil to foam up blowing up engines. That was a lot of years ago though. There are a ton of options for tanks, but you can pick up a V tank for under $500 which makes it a good buy. Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 06:04 AM |
