> Group buy wiper assembly offset standoff, $6.80 each, $12 after the GB
Mikey914
post Mar 6 2014, 02:14 AM
The rubber man
If you've done a bare metal restoration, you may well be familiar with this part. probably 80% of all the cars out there have the factory original offset isolators. Most have deteriorated and cracked if not sheared.
Mine actually split in 2. These are a no brainier to replace if you are doing a complete restoration. The straight ones available at ace will not cut it here.
Shown in the instruction page of the maintenance manual is the only reference to the nut that holds the assembly in. ***The easy way to get at the nut is to remove the speedometer***
I will have these in about 2 weeks with some other items so you will be able to combine for shipping.
bdstone914
post Mar 6 2014, 05:29 PM
bdstone914
Mike,
This is definitely a needed item as I have never seen a good one on all the parts cars I have seen. Many members are probably not aware of it. Is your going to be made better than the OE? It seems to be a weak design. The 911 wiper assemblies use a thick web like a muffler hanger.
Bruce
Mikey914
post Mar 6 2014, 07:50 PM
The rubber man
QUOTE(bdstone914 @ Mar 6 2014, 03:29 PM) *
Mike,
Bruce
Mine is just like OE with new rubber. I figure it should be good for another 30 years+.
Mikey914   Group buy wiper assembly offset standoff   Mar 6 2014, 02:14 AM
Mikey914   The cracked OEM is shown below   Mar 6 2014, 02:15 AM
Garold Shaffer   :trophy:   Mar 6 2014, 07:12 AM
Mikey914   I really thought there would be more interest for ...   Mar 6 2014, 12:23 PM
sbsix   I really thought there would be more interest for...   Mar 6 2014, 01:51 PM
Mikey914   I figured with the number of full restorations thi...   Mar 6 2014, 02:15 PM
sbsix   I figured with the number of full restorations th...   Mar 6 2014, 03:31 PM
barefoot   I figured with the number of full restorations th...   Mar 7 2014, 09:04 AM
JmuRiz   Interesting, never even thought about that part.   Mar 6 2014, 03:36 PM
Mikey914   Interesting, never even thought about that part. ...   Mar 6 2014, 07:52 PM
Mike Bellis   I want some. :)   Mar 6 2014, 04:26 PM
JamesM   as always, put me down for 3 cars worth   Mar 6 2014, 05:17 PM
bdstone914   Mike, This is definitely a needed item as I have ...   Mar 6 2014, 05:29 PM
Mikey914   Mike, This is definitely a needed item as I have...   Mar 6 2014, 07:50 PM
John Jentz   I need one.   Mar 6 2014, 07:08 PM
mrbubblehead   mark, put me down for 4.   Mar 6 2014, 08:18 PM
cconcepcion   I need a pair asap… Thanks, Cesar   Mar 6 2014, 08:23 PM
X911IC   Mark, are there one or two per car? Count me in f...   Mar 6 2014, 09:00 PM
walterolin   I'll take two.   Mar 6 2014, 10:02 PM
FL 000   I'll take one. Mine broke when I removed it, a...   Mar 6 2014, 10:17 PM
Eric_Shea   One per car. I'll probably take a dozen. M...   Mar 6 2014, 10:17 PM
McMark   I was just thinking about this part. I need 5 rig...   Mar 6 2014, 11:02 PM
Qarl   I'll take 2   Mar 6 2014, 11:18 PM
Mikey914   Thanks guys, it helps, and you will like these.   Mar 6 2014, 11:53 PM
eyesright   I need three.   Mar 7 2014, 02:41 AM
DEC   I take 3 with my next order   Mar 7 2014, 03:59 AM
CptTripps   1 car worth for me...   Mar 7 2014, 04:36 AM
mharmon   I'll take 3   Mar 7 2014, 09:21 AM
Zimms   I am in for 1 car worth   Mar 7 2014, 10:28 AM
charlesmac   Perfect timing! I need at least 2, maybe more...   Mar 7 2014, 12:10 PM
Mikey914   These are done and will be posted up Monday, along...   Mar 29 2014, 11:14 AM
Sfreeman615   I'll take 2 please!   Mar 29 2014, 03:16 PM
d914   in for two...   Mar 29 2014, 03:41 PM
larryM   i will take a pair - good thing to have in the spa...   Mar 29 2014, 04:37 PM
Mikey914   PM has been sent to all. Thanks, Mark.   Apr 2 2014, 12:31 PM
sbsix   Mark, I'm in for one, as well. Do you want pai...   Apr 2 2014, 01:56 PM
rgolia   count me in for one Mark. Sending you a PM regard...   Apr 2 2014, 02:55 PM
bigkensteele   In for 1.   Apr 2 2014, 07:18 PM
porbmw   Hi Mark 2 please. Will get in touch re some other...   Apr 10 2014, 04:48 PM
- Lo-Fi Version Time is now: 15th June 2026 - 03:01 AM
