| Mikey914 |
Mar 6 2014, 02:14 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,782 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
If you've done a bare metal restoration, you may well be familiar with this part. probably 80% of all the cars out there have the factory original offset isolators. Most have deteriorated and cracked if not sheared.
Mine actually split in 2. These are a no brainier to replace if you are doing a complete restoration. The straight ones available at ace will not cut it here. Shown in the instruction page of the maintenance manual is the only reference to the nut that holds the assembly in. ***The easy way to get at the nut is to remove the speedometer*** I will have these in about 2 weeks with some other items so you will be able to combine for shipping. Attached thumbnail(s) Attached image(s)
| JmuRiz |
Mar 6 2014, 03:36 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,633 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Interesting, never even thought about that part.
| Mikey914 |
Mar 6 2014, 07:52 PM
Mikey914 Group buy wiper assembly offset standoff Mar 6 2014, 02:14 AM
Mikey914 The cracked OEM is shown below Mar 6 2014, 02:15 AM
Garold Shaffer :trophy: Mar 6 2014, 07:12 AM
Mikey914 I really thought there would be more interest for ... Mar 6 2014, 12:23 PM
sbsix
I really thought there would be more interest for... Mar 6 2014, 01:51 PM
Mikey914 I figured with the number of full restorations thi... Mar 6 2014, 02:15 PM
sbsix
I figured with the number of full restorations th... Mar 6 2014, 03:31 PM
barefoot
I figured with the number of full restorations th... Mar 7 2014, 09:04 AM
Mike Bellis I want some. :) Mar 6 2014, 04:26 PM
JamesM as always, put me down for 3 cars worth Mar 6 2014, 05:17 PM
bdstone914 Mike,
This is definitely a needed item as I have ... Mar 6 2014, 05:29 PM
Mikey914
Mike,
This is definitely a needed item as I have... Mar 6 2014, 07:50 PM
John Jentz I need one. Mar 6 2014, 07:08 PM
mrbubblehead mark, put me down for 4. Mar 6 2014, 08:18 PM
cconcepcion I need a pair asap…
Thanks, Cesar Mar 6 2014, 08:23 PM
X911IC Mark, are there one or two per car? Count me in f... Mar 6 2014, 09:00 PM
walterolin I'll take two. Mar 6 2014, 10:02 PM
FL 000 I'll take one. Mine broke when I removed it, a... Mar 6 2014, 10:17 PM
Eric_Shea One per car.
I'll probably take a dozen.
M... Mar 6 2014, 10:17 PM
McMark I was just thinking about this part. I need 5 rig... Mar 6 2014, 11:02 PM
Qarl I'll take 2 Mar 6 2014, 11:18 PM
Mikey914 Thanks guys, it helps, and you will like these. Mar 6 2014, 11:53 PM
eyesright I need three. Mar 7 2014, 02:41 AM
DEC I take 3 with my next order Mar 7 2014, 03:59 AM
CptTripps 1 car worth for me... Mar 7 2014, 04:36 AM
mharmon I'll take 3 Mar 7 2014, 09:21 AM
Zimms I am in for 1 car worth Mar 7 2014, 10:28 AM
charlesmac Perfect timing! I need at least 2, maybe more... Mar 7 2014, 12:10 PM
Mikey914 These are done and will be posted up Monday, along... Mar 29 2014, 11:14 AM
Sfreeman615 I'll take 2 please! Mar 29 2014, 03:16 PM
d914 in for two... Mar 29 2014, 03:41 PM
larryM i will take a pair - good thing to have in the spa... Mar 29 2014, 04:37 PM
Mikey914 PM has been sent to all.
Thanks, Mark. Apr 2 2014, 12:31 PM
sbsix Mark, I'm in for one, as well. Do you want pai... Apr 2 2014, 01:56 PM
rgolia count me in for one Mark. Sending you a PM regard... Apr 2 2014, 02:55 PM
bigkensteele In for 1. Apr 2 2014, 07:18 PM
porbmw Hi Mark
2 please.
Will get in touch re some other... Apr 10 2014, 04:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th June 2026 - 10:28 PM |
