Group buy wiper assembly offset standoff, $6.80 each, $12 after the GB |
Mikey914 |
Mar 6 2014, 02:14 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
If you've done a bare metal restoration, you may well be familiar with this part. probably 80% of all the cars out there have the factory original offset isolators. Most have deteriorated and cracked if not sheared.
Mine actually split in 2. These are a no brainier to replace if you are doing a complete restoration. The straight ones available at ace will not cut it here. Shown in the instruction page of the maintenance manual is the only reference to the nut that holds the assembly in. ***The easy way to get at the nut is to remove the speedometer*** I will have these in about 2 weeks with some other items so you will be able to combine for shipping. Attached thumbnail(s) Attached image(s) |
FL000 |
Mar 6 2014, 10:17 PM
Member Group: Members Posts: 397 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I'll take one. Mine broke when I removed it, and I did order a couple that looked compatible from McMaster...but would rather go with a sure thing.
Thanks |
Lo-Fi Version | Time is now: 1st June 2024 - 12:00 PM |
