Stock windshield washer system, Worth saving? |
saigon71 |
Mar 12 2014, 07:13 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I continue to address comfort/drivability projects on the teener. I plan on driving the car a lot this year and need operational windshield washers.
When I filled up the reservoir and connected the stock system to the spare tire, all the fluid leaked out below the gas tank and deflated the spare tire. My question is...is the stock system worth sorting out and using for DD purposes or should I just go with a pump? Thanks! |
GeorgeRud |
Mar 12 2014, 07:52 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
You might find that replacing it with a simple pump may be the easiest route, but you will have to come up with a switch to control it.
There is supposed to be a limiter in the air line from the spare that limits how low the air pressure can get in the spare tire. If you replace that, you might find that there is simply a bad connection in a water line. Usually the problem is at the switch on the steering column, but the leakage would be into the interior if that was the case. |
Lo-Fi Version | Time is now: 12th June 2024 - 06:42 AM |
