Has anyone found alternative 90 degree spark plug boots, for carbs with tangerine racing throttle linkage |
stugray |
Mar 16 2014, 01:44 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I am curious if anyone has found 90 degree spark plug boots that fit onto the plugs with carbs and the CFR throttle linkage.
When the wires come straight up, out of the shrouds they have to bend and rest against the bottom of the carbs. I am guessing there is some leakage of the spark with the wires rubbing like that. Any ideas? |
rhodyguy |
Mar 17 2014, 10:34 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
if you install the clips/holders i asked about you can usually steer the wires away from troublesome situations and keep the wires OFF of the tin. esp evident in your second picture. then the holes are plugged too. are there any particular reasons you mounted the cable linkage on the rear of the carbs and the coil way back on the tin?
Lo-Fi Version | Time is now: 1st June 2024 - 06:53 PM |
