Scott S |
Small Member ![]() ![]() ![]() Group: Members Posts: 1,698 Joined: 30-April 03 From: Colorado Member No.: 633 ![]() |
Hi All -
I am going to use a 911 heated window switch to control the fan on my oil cooler. I am trying to verify the different tabs on the back of the switch. Here is a diagram of the back: ![]() I am guessing that the numerical definitions are standard for all porsche switches - but I dont want to burn up the switch or wiring by making this assumption. Here is how I think things should go: 31 = Ground 58 = light inside the switch <-- is this + or - ? 15 = keyed power I = Load/Accessory #1 III = Load/Accesory #2 Can anyone verify? Also, is #58 a positive or negative lead? When installing a standard off the shelf FLAPS rocker switch, the lead to make it illuminate is negative. However, those types of switches do not have a ground - they just interrupt the power lead to the accessory. On a side note, this is a single postion pull switch - weird that is has what appears to be two load "outputs". Thanks a million for any help!! Scott S |
Lo-Fi Version | Time is now: 14th July 2025 - 02:32 AM |
